View unanswered posts | View active topics It is currently July 5th, 2025, 1:52 pm
 Manifolds
Post Manifolds
Notsmartcar is after a later 2cv manifold to fit a single choke carb. The engine he has is a 602 with oil filter - an m28? Which 2cvs had this single choke/oil filter setup?
May 7th, 2011, 10:56 am
Post Re: Manifolds
AZ (Series KA) from 2/1970 until 7/1978?
M28/1 engine, 8.5:1 CR
May 7th, 2011, 11:19 am
Post Re: Manifolds
Does that actually exist, without cutting and welding that is? I always thought the flat plane flange early 602 engines had the big single choke carb and the late oil filter cranked plane flange engines used twin choke carbs.
You can't use a 425 manifold BTW, tried that :oops:
May 7th, 2011, 11:27 am
Post Re: Manifolds
? :lol:
You know this car quite well...
IMG_2640 by slcchassis, on Flickr
May 7th, 2011, 11:43 am
Post Re: Manifolds
That's what I thought too. I hadnt realised that citroen had continued to use single choke carbs into the AZ KA series.
I do have a book on this at home... I shall look and find out what carbs these were.
May 7th, 2011, 1:18 pm
Post Re: Manifolds
Sam,
check with Matt?
I'm sure he'll confirm that the best drummers had the single choke Solex 34 carb/organ pedal throttle pedal/ frotteurs & batteurs/ bus steering wheel mix...
:lol:
May 7th, 2011, 3:07 pm
Post Re: Manifolds
ken wrote:
? :lol:
Oh yeah; so I do :oops:
May 8th, 2011, 8:14 pm
Post Re: Manifolds
By the way does anybody want an M4 Manifold or 2?
May 9th, 2011, 9:33 pm
Post Re: Manifolds
Oi. You're curator of the world's most impressive collection of slightly buggered big carb M4 manifolds. You should be proud of that position, not trying to palm 'em off on people.
May 9th, 2011, 9:58 pm
Post Re: Manifolds
Oi. You're curator of the world's most impressive collection of absolutely mint and very rare big carb M4 manifolds. You should be proud of that position, however I totally understand that you may want to sell them for a small profit.
May 9th, 2011, 10:19 pm
