View unanswered posts | View active topics It is currently July 5th, 2025, 2:09 pm
Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 light flywheel heavy flywheel light flywheel heavy flywheel
Post Re: light flywheel heavy flywheel light flywheel heavy flywh
Depends how you use your car, I suppose ... lots of motorway mileage means a heavy flywheel is the way to go, mostly pottering around town means you're probably better off with a lighter one. Personally I've used both over the years and am far from convinced I could actually tell the differencce in a blind test.
April 26th, 2011, 2:45 pm
That's why I asked the question earlier.
What is the difference between the weight of a 'heavy+spring clutch and a 'light'+diaphragm clutch?
John Jordan
April 26th, 2011, 2:53 pm
oh bolloks im not going back up to the lockup to start weighing flywheels ;)
its more and the weight is out at the circumference therefore making it a highly desirable "Kinetic" one.
April 26th, 2011, 3:19 pm
Simply comparing the weights won't give an accurate basis for comparison, since the rotational inertia of a flywheel is dependent on the location of its mass.
If you look at a 'heavy' flywheel, especially of the type fitted on older engines such as the M4, you'll notice that there is a lot more metal near the outer edge where its 'flywheel effect' is much greater.
< http://www.freestudy.co.uk/dynamics/mom ... nertia.pdf >
I'll leave you to crunch the numbers, whilst I get on with some more low value metal bashing... :lol:
April 26th, 2011, 3:21 pm
yes but i can now have a diaphram clutch with a heavy flywheel it seems
just off to college for a dose of inglish ;)
i will return back and take a picture of gear box with mr tape measure next to it :)
its all falling into place :) so looks like hjeavy flywheel will be acceptable now
my question is can i keep the box ive got in my car, or is the clutch mounted on the box not the heavy flywheel on the engine..~?
April 26th, 2011, 6:46 pm
The clutch is mounted on teh flywheel. The only thing you'll need to change on the gearbox is the clutch release bearing, which is clutch specific.
April 26th, 2011, 6:58 pm
righyto thanks jon, answered that question, and i assume that can be done with the box in the car?
just reluctant to take the box out as it means messing with the breaks and i dont want to mess with the breaks...
thinking about sticking the dyane engine in next week one evening after work, got a good lit workshop, shall ask boss tomoro, and seeing what happens,
better take push bike just incase!!
April 26th, 2011, 7:02 pm
Jameswallace wrote:
righyto thanks jon
OT alert!!!!!!
James, how come you spell Johns' name without an H and my name (Jon) with an H? :twisted: ;)
April 26th, 2011, 7:12 pm
Jon,
do you need to ask, when James can come up with corkers like this for our entertainment and delight? ;)
"in heinshite i should of asked,"
spanners wrote:
Jameswallace wrote:
righyto thanks jon
OT alert!!!!!!
April 26th, 2011, 7:18 pm
ken wrote:
Jon,
spanners wrote:
Jameswallace wrote:
righyto thanks jon
OT alert!!!!!!
True enough I suppose but, nonetheless, I'm joining Russ and Aidan on the "Spell our names correctly masacre tour 2011"! :lol:
April 26th, 2011, 7:23 pm
