View unanswered posts | View active topics It is currently November 21st, 2025, 6:36 am
 8.5:1 and 9:1
Post 8.5:1 and 9:1
Where's the difference, the piston, barrel or both?
Fanks
April 24th, 2011, 8:27 pm
Post Re: 8.5:1 and 9:1
Piston. Barrels are all the same.
April 24th, 2011, 8:28 pm
Awesome, thanks Russ :D
April 24th, 2011, 8:34 pm
So if your barrels are ok all you need are a set of pistons and rings for a cheap upgrade or am I missing something?
Life begins at the end of your comfort zone
April 24th, 2011, 10:02 pm
Yes, although if you're buying a set of new pistons and rings you might aswell buy barrels too. I don't think it's much more expensive.
April 24th, 2011, 10:05 pm
Yep,
if your 8.5:1 pistons and the barrels are in good condition, machining 0.25mm off the top of the barrels will increase the effective CR to close to 9.0:1... ;)
April 24th, 2011, 10:35 pm
I'll be looking to replace the barrels and pistons on my 2CV soon, but will keep with 8.5:1 as the bottom end would still have done over 205 thousand miles and I wouldn't want to put too much extra stress on it.
April 24th, 2011, 10:44 pm
What increase in power are we talking about - 3 or 4 bhp? (I'd have thought that would be 'noticeable'?)
Will it still be as **cough** 'smooth' at tick-over?
Thanks.
April 25th, 2011, 1:31 pm
Dont think you will notice any difference in tick-over smoothness - even if you put 8.5's on you will notice a big difference over an old tired engine and rings
April 25th, 2011, 1:40 pm
^^^ What he said^^^
Even just taking the heads off the Ami and "lapping" them back in has made a massive difference!
April 25th, 2011, 1:42 pm
Users browsing this forum: No registered users and 15 guests
