View unanswered posts | View active topics It is currently July 5th, 2025, 1:30 pm
Reply to topic  [ 587 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 59  Next
should it even be soldered??
It shouldn't be soldered, there are 2 spade connectors there normally. Someone has been "creative".
April 11th, 2011, 1:20 am
There's been a lot of that :lol:
Cheers for the info - guessed that wasn't right. A future project might be replacing the speedo and fuel guage, there's a spare in the shed.
At the moment though it doesn't fit into the 'what's needed for MoT' mantra. It'll come under the 'while girlfriends at uni' project list :)
April 11th, 2011, 1:57 am
toomany2cvs wrote:
So Inspired was I by James Wallace
This was a huge mistake.
We could've told you that...
thanks i geuss :evil: :? :x :| :cry:
sam i had 2 dash's so i could simply swap, i love the dash ive got, and the painted speedo surround ;)
if you want to do it, then do it, take your time, and while your there fix the soldered ends and anything else, do it once do it properly
April 11th, 2011, 9:24 am
are you feeling alright?
April 11th, 2011, 10:34 am
I have a problem with my speedos...
:roll:
The replacement reads in MPH. Will my length of cable fit?
On the plus side the fuel tank gauge actually has proper connections.
Also, 'the zit' on the dash - what's it do. There's a bulb in there but it never comes on :?
When's it supposed to come on?
Ill change the bulb and see if that makes a difference.
And why is it so... HUGE?
April 12th, 2011, 12:31 am
that sir, is not a problem many complain about
April 12th, 2011, 12:57 am
I'd imagine the speedo will be miles out. Mine is.
April 12th, 2011, 1:24 am
Charge warning light. Remember that conversation?
April 12th, 2011, 9:01 am
You'd be better off wiring it up as an oil pressure light.
April 12th, 2011, 9:05 am
Vaaaaguely.... so it comes on if the battery's not charging? Or low?
Good thing it's neve been on then :)
A lot of what you told me was lost in the excitement/fear of buying a van :lol:
See you later sir
April 12th, 2011, 9:09 am
