View unanswered posts | View active topics It is currently November 21st, 2025, 7:49 am
Reply to topic  [ 9 posts ]
 Points box
Post Points box
Why's my points box full of oil?
April 11th, 2011, 8:43 pm
Post Re: Points box
Because the front oil seal is leaking.....
It may just be the crank case pressurisation issue rather than a terminal seal.
April 11th, 2011, 8:45 pm
Post Re: Points box
I assume there's an oil seal on the end of the cam behind the advance weights? Nothing too involved or owt?
April 11th, 2011, 8:49 pm
Post Re: Points box
No seal on the camshaft, only an oil return scroll like that on the gearbox input shaft...
Crankcase vacuum test? :(
April 11th, 2011, 8:52 pm
Post Re: Points box
No seal Russell but a oil sling cut in to the cam shaft, keeping the oil out. Sound the crankcase ventilation is kaput (oil breather)
April 11th, 2011, 8:53 pm
Post Re: Points box
I still haven't done one of those. It's had a new breather this week since the one I rebuilt had a hole in it. I'll stick a new set of points in it and mop it and see what happens.
Thanks guys.
April 11th, 2011, 8:58 pm
Post Re: Points box
Russell,
for comparison purposes...
Points boxes by slcchassis, on Flickr
April 11th, 2011, 9:06 pm
Post Re: Points box
There's a seal on the crank that can dribble into the point box. I'd check the easy stuff first though. Gasket on the reniflard, crank case pressurisation..
I have a new (pattern Cassis) reniflard that's been put together incorrectly; it's twisted and hits the fan housing. You're welcome to it if you want to cut it apart and fix it.
April 11th, 2011, 9:07 pm
Post Re: Points box
At least I know where to come if I need a spare...
Thanks 2-fiddy, I'm going to re-flap this one at some point.
April 11th, 2011, 9:09 pm
