View unanswered posts | View active topics It is currently May 1st, 2026, 4:17 pm
Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3  Next
 Engine breather
Post Re: Engine breather
Did a quick chat with him at the last 24h Franchorchamps, looks ok. to me
but heard something like your story several times.
(I never orderded something at his shop) (I didn't order anything anywhere for the last 10 years) :lol: :lol: (iv'e got a big spare part garage!!)
March 31st, 2011, 5:13 pm
We order from him, but he can't/will only deal with french speaking.
March 31st, 2011, 6:46 pm
I think the 4x4 crew were talking about PP and were not entirely positive. I'm not spending €70 on something that can be repaired for less than €1!
March 31st, 2011, 7:52 pm
Nice work russ, even if it dosnt last, its taught me a thing or two about breathers.
March 31st, 2011, 8:33 pm
Nice job, Russ. Don't suppose you have access to a manometer to test whether it's working?
How thick was the old rubber diaphragm you removed compared to the mudflap? I wonder if the air pressure/suction will be able to overcome something as thick as this?
April 1st, 2011, 12:04 am
It was the same thickness which is why I used it, the only other bits of rubber about where old inner tubes and tractor tyres. Not only do I not have a manometer, even if I made one I don't currently have a working engine to test it on either. I'm going to rewrite the original post with better pictures and more explanations and sticky it when I do a second one with the improved and hopefully long lasting rubber flap.
April 1st, 2011, 12:42 am
It's not hard to get one of those "manometers". Just a bit of clear rubber hose, a piece of wood, some "big headed" screws and some water/beer/coolant/windscreen washer fluid or whatever is in the garage.
Or actually, if you think "less is more-always", just the rubber hose with some water and hold it in a U-shape. It will give you an idea of the working state of the breather.
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
April 1st, 2011, 7:02 pm
use lhm in the tube and if the engine decides to suck the contents of the tube into the engine internals then its not a full oil change ;) or a fubared engine :lol:
April 1st, 2011, 10:15 pm
tent peg cable tie and washer tube
April 1st, 2011, 10:20 pm
If that happens, there's some serious misjudgments going on :lol:
Sean, next time I will use cable ties! Simple and clever indeed.
April 2nd, 2011, 3:07 pm
Users browsing this forum: No registered users and 98 guests
