View unanswered posts | View active topics It is currently July 4th, 2025, 11:19 am
Reply to topic  [ 587 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 59  Next
Many thanks indeed sir, although I must concede that on closer inspection the wings look very brush painted, but a bit of flatting back in a few weeks will help.
We were just discussing how to deal with the rear panels, looks like a lot of rubbing down in my dad's near future!
March 24th, 2011, 12:58 am
wow, just paid £39 in including delivery for a battery from these chaps http://www.advancedbatterysupplies.co.uk/ guaranteed for 4 years :)
March 24th, 2011, 1:26 am
sure i could of sorted you out with a tractor battery cheaper ;)
March 24th, 2011, 1:44 am
and ht leads?
and a new carrier?
and a new bulkhead?
:lol:
March 24th, 2011, 1:46 am
I was thinking from rust on the seems, they look ok, but thought id check before I paint them and what not. It'll certainly be less faff if I can stick them straight on rather than move tyres/rims around.
Shove 'em on and try 'em before you paint 'em?
March 24th, 2011, 10:15 am
If they're 2CV rims they should fit. I have however had clearance problems with the wider "other" A series rims, there can be a conflict twixt rim and inertia damper.
March 24th, 2011, 10:56 am
<scratches head> All 15" A-series rims are the same width - 4"...
You thinking of 4.5" G rims?
March 24th, 2011, 11:00 am
Thinking about it they may well have been. I took them off a French 2CV disk brake car and tried to fit them to a drum brake AK 400; and then wondered why I had an immovable van :lol:
March 24th, 2011, 11:05 am
I'll give them a trial fit tonight to make sure the seams are clear and paint them up over the next few evenings.
Just bought that sound proofing - looks good.
March 24th, 2011, 11:54 am
So, trial fitted the spare rims on Hetty this evening. The wheel nuts were pretty damn tight but a bit of jumping on a wheel brace and some WD40 had them off.
I got 9 rims with Hetty. 5 on the car, 4 to go on with 145s fitted.
Of those with 145s fitted, I'd say 2 of them are okish. 2 are shot at the seems. These are later welded type wheels.
The spare on the van is gone at the seems.
The 4 on the van are early riveted type and all have surface rust, particularly on the outer rim.
I can never decide what I do about wheels. I'm sorely tempted to fork out and buy new ones as I know they'll be solid.
The alternative is to use the 2 okish ones and see what I can salvage from my garage - I think I may have the better of the old rims from my car. But then I have to faff around sanding, priming and trying to make a half decent paint job in the knowledge that they will, eventual, still need to be replaced.
What to do...
March 24th, 2011, 10:29 pm
