View unanswered posts | View active topics It is currently November 21st, 2025, 8:01 am
 What oil?
Post Re: What oil?
I've been dreading this, so instead of asking what to use, I have an awful lot of halfrauds finest 15W40 mineral oil - will it do? :?
March 19th, 2011, 1:13 pm
Post Re: What oil?
I just sticks Tesco 15/40 in mine, it now on 202,800+miles.
March 19th, 2011, 1:19 pm
Post Re: What oil?
And therefore a testament that you don't have to spend lots on oil to keep your engine going well. I suspect you change for filter often though.
March 19th, 2011, 1:41 pm
Post Re: What oil?
I generally change the filter as and when I change the axle bolts, around 3-6000 miles. I don't think brand really matters as long as the engine has oil in it and you change it at regular intervals.
March 19th, 2011, 2:37 pm
Post Re: What oil?
any oil is better than air
March 19th, 2011, 4:14 pm
Post Re: What oil?
Dont know what all the angst over oil is about
as long as you check the API numbers(or eqivalent) and go for the best you an afford
dirty brand x is almost certainly worse for your engine than clean morrisons
as for the diesel - its 'cause its the right weight AND cheap 25l for <£40 from costco and the added benifits of the higher detergent are secondary.
March 19th, 2011, 4:33 pm
Post Re: What oil?
As long as its the recommended type (15W40 or whatever), can you actually tell the difference between oils unless you are involved with the maintenance or repair of the engine?
Just put some in. And if you drive an Allegro, put some more in next week. And then some more next week. And some more the week after. :roll: :lol:
March 19th, 2011, 5:15 pm
Post Re: What oil?
GTX when it's on offer, mostly Halfords own brand. Oil and filter annually or every 3000 miles. Any oil is better than no oil.
March 19th, 2011, 11:57 pm
Post Re: What oil?
Wonder if I've been neglecting oil and filter changes, by using Citroen's recommended service intervals of 5,000 miles for the oil and 10,000 miles for the filter? :?
Doesn't seem to have harmed any of the engines, with the daily driver's engine well on its way to a quarter of a million miles... ;)
( using Wilko's 10W40 semi-synthetic these days.)
March 20th, 2011, 12:21 am
Post Re: What oil?
My 'maintenance guide Petrol 87' has 6000 miles for oil and 12000 for oil filter. I wish Citroen would be consistent.
John Jordan
March 20th, 2011, 12:42 am
