View unanswered posts | View active topics It is currently November 21st, 2025, 7:05 am
 Sparkplug- insert or helicoil
Post Sparkplug- insert or helicoil
Used both but what have you used and did it last?
March 11th, 2011, 11:30 am
Post Re: Sparkplug- insert or helicoil
Helicoil, I've found the Snap On style inserts come out with the first spark plug change.
March 11th, 2011, 11:39 am
With or without nut-lock?
March 11th, 2011, 12:04 pm
Change the cylinder head, you know it makes sense in the long run.
March 11th, 2011, 4:30 pm
One of my cylinders has a threaded insert. no problems with it since it had been done. but i have not been there when during spark plug changes so im not sure what would be better.
March 11th, 2011, 4:56 pm
No I'm not a parts exchanger, I'm a repairer :mrgreen:
March 11th, 2011, 4:58 pm
As in loctite? You don't use loctite with a helicoil.
March 11th, 2011, 5:09 pm
GSA plug with the longer threaded part?
Just dont wind it in too far...
March 11th, 2011, 5:22 pm
No, but you may well do with an insert.
March 11th, 2011, 6:01 pm
Viking,
I've used KD inserts a long time back, but even with the correct ( high temperature?) thread locking compound, they had a habit of coming out with the plug. :(
< http://www.mytoolstore.com/kd/kdengi11.html >
After that, the local motor cycle shop would fit Timeserts, but only if the head was removed from the engine.
< http://www.timesert.com/html/mtrcsert.html >
Those were very good, however the bike shop closed down so I started using Helicoils and have never had a problem with one I've fitted.
At Kelso, even though I wasn't connected with the 'on site' garage, they ran out of Helicoils and 'borrowed' more than a few of the supply of spark plug Helicoils I happened to be carrying with me.
Paul,
interesting that you should advise changing the head, since a time served engineer I know would fit helicoils in the heads of any engines he was building, as a matter of course.
Not just the plug threads, but the M7 threads on both the oil feeds and inlet manifolds as well...
March 11th, 2011, 7:17 pm
