View unanswered posts | View active topics It is currently September 21st, 2025, 9:41 am
Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Uprated springs? what? how?
Post Re: Uprated springs? what? how?
Will post some pics of my mods to show how longer springs can be fitted.
NB. A change in the wire Diameter makes a large change to the spring rate
eg 1mm change can alter the rate 250 ft/lb try the calulator
ps Are you the Harley that did the Turbo GS?
May 6th, 2009, 9:54 am
Matt S wrote:
why not just buy the uprated springs that 'normal' suppliers advertise.
i guess its more expensive to have some new ones made than to buy those ones?? i dunno.
I come from alanddownunda... shipping is to expensive to Australia, I have had several quotes and cheaper for me to purchase locally, + Ecas do did not reply to my request.
subarupete wrote:
No, but i do have an EFI megasquirt 2cv and am currently building a Visa engine with twin spark and supercharger :twisted: :D
Does anyone have the specs of their uprated springs? wire diamiter, length, number of coils?
Cheers
May 6th, 2009, 10:48 am
Harley wrote:
I come from alanddownunda... shipping is to expensive to Australia, I have had several quotes and cheaper for me to purchase locally, + Ecas do did not reply to my request.[/quote]
Excellent reason, didnt realise you were on t'other side of the globe mate :)
May 6th, 2009, 10:55 am
OK on the megasquirt, what are you using for a throttle body? I have acquired a Nissan micra with TPS etc but thats all at the moment.
Have taken springs off for a, spring Clean:)
They are uprated springs and etched as follows
Originally from ECAS for 2cv racing??, but will enquire and try to get the specs...
Front
2CV F 200 x 1050 lbs
The 200 is the length in mm, have measured wire diameter @ 15.9mm No . of Coils seven counting from the flat ends
Rear
2CV R 230 x 1050 lbs
The length is 230mm, Wire diameter @16.75 No. of coils 8
See pics of set up
Rear mount, adaptor made by Louis Barbour, round plate with tube to locate spring.
Front mount
Use standard threaded tube no rubber doughnut.
Shortened spring cups
Rear Springs
Left hand IS uprated, dont know why it is so long? shall enquirte Right Hand is standard
Front Springs
Note the left is actually no longer parrallel, I drove many off road miles with open springs
so I reckon spring can or the like are essential, I think the original designer knew a thing or two!
The current set use the 4 rear spring to get a good ride height, but they are actually to stiff,
May 6th, 2009, 3:11 pm
Post Injection
Is this yours
http://www.msruns.com/viewtopic.php?f=99&t=22687
its Ace!!
May 6th, 2009, 5:09 pm
Re Spring rates i could tell all!!
As i have all this info
Basically go no more than 10 to 25% up on normal rate
+ you can lengthen the rear spring by about 30 mm
and still get the springs in the original cans
I can do of the shelf a set of normal rate + 25 %
we use these in the off roaders
they should just fit in the cans
However MOST important you must use the Ami 8 spring buffer Rubbers as
the smaller dia 2cv ones will just burst
Typical spring costs are £35 each = 140 for a full set
But if anyopne wants a set they should bell me before end of May cos i'll be gone for 3 months after that date!!
dad
PS 4x4 type chassis but for 4x2 use should be available by year end
May 6th, 2009, 9:49 pm
Louis, which cars have this set up with cans???
May 6th, 2009, 10:05 pm
Hi Louis,
Thanx for the info. Can you provide me with the wire diameter of the uprated springs you use + number of coils, etc. Do you recommend lengthening the rear spring 30mm? is this done buy adding extra coils?
Where can i get the Ami 8 spring buffer Rubbers from?
You mean this part?
Ecas have 170% uprated for lowered cars, i assume this is 70% harder, not 170% harder... But i do remember reading that racers go 100%+ harder.
I am still planning to run at standard height, most of the time;)
Cheers
May 7th, 2009, 11:08 am
Post Re: Injection
subarupete wrote:
:) Thx,
Check out http://snail.s4.bizhat.com/viewtopic.php?t=801&mforum=snail for what i am currently doing with it, also look at Injecting your 2cv
May 7th, 2009, 11:13 am
Harley,
Have seen you good work on the Snail forum.
Thanks for the links
The spring dimensions were in my post, the details from the engraving on the spring some I measured
May 7th, 2009, 11:33 am
Users browsing this forum: No registered users and 326 guests
