The project.. called Bella
Russell
 Re: The project.. called Bella
This is a very simple piece to repair, when I get home I'll post some pictures of one I did. Much easier to do properly than weld a sheet over to give the appearance of an old car.
| May 3rd, 2009, 8:29 pm |
Passe-Partout
2cv4x4 wrote: make it look like an older shell just weld over it Ha! we actually discussed that idea! but I don't think I'd ever achieve a consistent finish overall.. Russell wrote: This is a very simple piece to repair, when I get home I'll post some pictures of one I did. Much easier to do properly than weld a sheet over to give the appearance of an old car. - thanks R, I'd be really keen to see that.
 --Graeme Mc
| May 3rd, 2009, 10:57 pm |
Passe-Partout
Milde update. I have left the 3/4 panel for now while I decide what's going to happen with it  and turned my attention to the corrosion at the LH rear seatbelt mounting. What initially appeared to be heavy but localised corrosion turned out after grinding etc to be fairly widespread! I'd been struggling with loosening the mounting bolt that was seized.  As the bolt become increasingly stuck it began to twist the semi corroded mounting plate and soon the reinforced plate added for the seat belt mounting was itself giving way in the wheel arch!   Looking up = looking BAD:  So I got the angle grinder to lop off the bolt and started to remove the crappy rusty grot.     Oh bumhats!  wire brush on the grinder:  More and more of the car vanishes....   So! this entire corner of the car is really quite rusty!! the rest of the car is very solid - including the opposite rear quarter which seems to have survived solidly. I suppose this LH side has succumbed to the ravages of the 'Gutter side' !
 --Graeme Mc
| May 6th, 2009, 1:11 am |
Russell
Late, but as promised:   Simply a piece of angle, approx 15mmx15mm welded in and sanded back. The curve at the end was put in by cutting a series of slits into one leg of the angle and curling it up, then welding the slits up and sanding. The curve along the bottom of the window was put in by simply using a rounded hammer and an anvil.
| May 6th, 2009, 9:23 pm |
louise2cv
that's my car that's my car that's my car
I love Russ I love Russ I love Russ
| May 6th, 2009, 9:25 pm |
JRW_91
lovin' the snatch
Joined: January 27th, 2009, 8:10 pm Posts: 1289 Location: Northampton
every window on my car looks something like yours did before the work... rotten along the bottom of the window... windscreen...back doors... rear windows.... shes gna need a fair bit of tlc before september... mot time.. again
 |-|-' 602 For Life
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6 1986 Sunrise Red 2cv6 1989 Vert Bamboo 2cv6 D*lly (in bits)
| May 7th, 2009, 12:51 am |
Passe-Partout
THX what sort of welder were you using for this bit?
 --Graeme Mc
| May 7th, 2009, 1:24 am |
Russell
Joe602 wrote: every window on my car looks something like yours did before the work... rotten along the bottom of the window... windscreen...back doors... rear windows.... shes gna need a fair bit of tlc before september... mot time.. again  Windows aren't MoT fail points. Passe-Partout wrote: THX what sort of welder were you using for this bit? A really gash 150a Clarke Mickey-Mouse-MIG, throwaway bottle job. IIRC I used 0.8 wire, but have since been using 0.6 which is nicer.
| May 7th, 2009, 9:24 pm |
Passe-Partout
 --Graeme Mc
| May 21st, 2009, 2:03 am |
JRW_91
lovin' the snatch
Russell wrote: Joe602 wrote: every window on my car looks something like yours did before the work... rotten along the bottom of the window... windscreen...back doors... rear windows.... shes gna need a fair bit of tlc before september... mot time.. again  Windows aren't MoT fail points. knew that bit russ.... they just look really really shite n tatty... and my back doors actually have no strength at all! you can push them in and out with a finger and im sure after a few more bumps my windows will just rattle themselves loose
 |-|-' 602 For Life
| May 21st, 2009, 9:17 am |
Users browsing this forum: No registered users and 482 guests |
