View unanswered posts | View active topics It is currently July 3rd, 2025, 12:22 am
Reply to topic  [ 9 posts ]
 Slight whiff of petrol in the cabin
Post Slight whiff of petrol in the cabin
Took a day off and went to see a mate in Hay on Wye yesterday and had loads of fun chucking the snail round the country roads, particularly on the way back in the dark.
One thing, though: I got a distinct whiff of petrol and oil in the cabin. I've checked the exhaust clamps and they're all tight and snug... What would be causing the smell to enter the cabin?
February 8th, 2011, 11:00 am
Post Re: Slight whiff of petrol in the cabin
leaking petrol? :?
check rubbery bits, float level and carb gasket
if you pressed the accelerator pedal once you had stopped and the engine was still hot it smells
February 8th, 2011, 11:05 am
Fumes psuhed out between the barrel and head.
February 8th, 2011, 11:12 am
Sean wrote:
leaking petrol? :?
Checked for leaks, and I'm pretty sure all is OK.
How can I check for this, and what is the remedy?
February 8th, 2011, 12:06 pm
Tighten your head bolts?
February 8th, 2011, 12:10 pm
Smiffy wrote:
Sean wrote:
leaking petrol? :?
The real remedy is to lap the joint between the head and the barrel. However a leaking head joint shouldn't smell of raw petrol, it has a sickly sweet exhaust smell.
There is a rubber pipe on top of the tank that is prone to failing (but normally causes bad starting). Also have a look at the fuel pipe joints themselves, look if the float bowl is trying to fall off. Petrol leaks will leave tell tale stains.
February 8th, 2011, 12:45 pm
twofifty AZU wrote:
...it has a sickly sweet exhaust smell.
That's a better description of the smell than my unimaginative "petrol in the cabin". In which case gents, I'm pretty sure we have our diagnosis!
Now, how would I "lap" the joint between the head and the barrel?
February 8th, 2011, 3:31 pm
Hold on a minute there bro!
James hasn't paid a visit yet ;)
(we loves ya really JW :lol: )
February 8th, 2011, 3:46 pm
Fair point!
February 8th, 2011, 4:02 pm
