View unanswered posts | View active topics It is currently May 2nd, 2026, 6:00 am
Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Strip n Dip
Post Re: Strip n Dip
twofifty AZU wrote:
Gas Mark 5 wrote:
What about the high zinc content paint on can get? If done properly how does that compare to galv/electro-plating?
It is very hard to overcoat. The idea behind galvafroid and similar high zinc coatings is that it functions as an anode. If there is an electrolyte, salty road spray to you and me, it effectively corrodes saving the steel.
It works great under wings and the like where appearance isn't that important, but used on a visible surface with shiny paint over it you tend to end up with the paint falling off.
To be honest it is a bit pointless in that application. Perforation pretty much always starts inside box sections and from edges, not in the middle of a panel. Conventional decent quality paint will preserve a sheet of steel pretty much indefinitely providing the coating is intact. If you use a good quality anti rust wax inside the box sections, keep drain holes free and don't allow mud to build up corrosion can be kept at bay.
Bilt Hamber Dynax is very effective. http://www.bilthamber.com/dynaxs50.html
I had a chat with a (multi-brand) specialist paint supplier - the "cold-galv" zinc paints are, apparently, great on freshly blasted steel. BUT if the steel's only "mechanically cleaned" (rotary wirebrush to you'n'me), it's not that great - it can't properly bond - and you're better with a more traditional primer. Which was cheaper, so they can't be accused of hard-sell.
February 2nd, 2011, 8:18 pm
I think having it dipped or otherwise de-rusted, then primed with this stuff gets my vote. It's a lot cheaper than any coating, and epoxy is far better than other primer paints for metal protection. http://www.rust.co.uk/popup.cfm?p_i=404984&p_n=404984
2-pack paint over this stuff and you're bombproof.
February 2nd, 2011, 8:27 pm
No, GM5, it wasn't Metallisation that I worked for!
I went on Metallisation's site on Sunday, and a sales person is now leaving daily messages for me! Little does he know that I'm a penniless 2CV driver!!
250: I guess anything would be worth it if it arrests the really aggressive rusting on parts like the floors, rear sweeps, bonnet hinges, etc... It'd be a case of weighing up the costs vs. the overall time saved on jobs like that, I suppose.
February 2nd, 2011, 8:29 pm
But that kind of rust starts in seams and cavities. I don't doubt the effectiveness of metal spraying as a process, on something like a sandblasted suspension arm it'll work brilliantly. I just doubt it is the most effective way of protecting vulnerable and inaccessable bits in a body shell.
There isn't anything especially magic about stopping rust, keep it clean, keep it dry, stop oxygen and electrolyte getting to the steel and it won't rust. The point is that it is an irreversible process. Most of us don't look at a clean piece of steel and think "I need to stop oxygen and electrolyte from getting to that". most of us, including me think "lovely, no work to do there".
Two years later we wonder how we're going to sort the rust which we could have prevented.
February 2nd, 2011, 11:16 pm
after re reading this post and noticing in my usual style, that im keen to do something and then do bugger all about it, and forget, ive emailed the company to see the logistics costs etc etc, so i can see about it, but it seems a lot cheaper than spending money on repairs in the future, and whilst my car is immaculate it would seem feesable to do it rather than fix it up when it degrades in 5 or so years,
depending if i can save up enough, and what they say about the logistics of it all, bending panels and other things, i would go for it
Having a completly rust proof 2cv would be amazing, id love to be less careful with it, saying that, im off to wash it in a minute in the dark ;)
October 20th, 2011, 8:13 pm
Don't wash it to vigorously in the dark... it will fall off... :mrgreen:
October 21st, 2011, 1:23 am
I ended uP building shelving instead
October 21st, 2011, 8:21 am
James, I think galvansing your car is a great idea, however, as you're so keen on your D*lly being original (which is why you spent £1400 on a galvanised Citroen Chassis) have you factored in the cost of having your D*lly resprayed afterwards? I can show you the bill for £3000 to have the rear of my D*lly sprayed in 2pack after it was shunted... and thats after you've had some fixing to adhere the paint to the galv.
But nonetheless, I'm interetsed to see the quote you get :)
October 21st, 2011, 1:24 pm
True
Painting wouldn't be feesable, it would cost too much,
I'd like it oven baked if it wad ever painted,
It probably won't happen :lol:
October 22nd, 2011, 9:00 am
