Rhythm Thief
Joined: March 10th, 2010, 12:37 am Posts: 1927 Location: Alone in my polytunnel with my pitiful competition onions
 Clutch cable adjuster thread
Anyone know what thread the adjuster barrel on the clutch cable is?
_________________ The best things in life aren't things.
| January 28th, 2011, 7:16 pm |
james2cv
Joined: April 18th, 2009, 8:01 pm Posts: 947 Location: Paris/Manc
 Re: Clutch cable adjuster thread
Might be completely wrong but I think one is 22mm the other 19?
| January 28th, 2011, 7:47 pm |
Rhythm Thief
You are wrong - they're 19mm and 16mm - and it's the thread I'm after, not the spanner size. But thanks anyway.
| January 28th, 2011, 7:49 pm |
james2cv
LOL. This is what happens when you know literally feck all about anything vaguely mechanical, and then think you actually do.
| January 28th, 2011, 8:00 pm |
M12x 1.0 I think
| January 28th, 2011, 9:14 pm |
That's the one... Are you in need of a nut, RT? Sean wrote: M12x 1.0 I think
| January 28th, 2011, 10:27 pm |
Rhythm Thief
Yes, sort of ... wot I'm trying to do is extend the adjuster barrel because it's the easiest way of extending the cable outer to make an Ami 8 cable fit an Ami 6 with the old type pedal assembly. I've done this by cutting an adjusted off an old cable, but now I need some kind of arrangement to hold it all together. ... I'll post some pictures when I get chance. They're so much better than words.
| January 29th, 2011, 12:10 pm |
Rhythm Thief
I suppose I should really have titled this "clutch cable adjuster thread thread".
| January 29th, 2011, 12:18 pm |
Russell
I reckon you may be best off buying an Ami8 pedal box. You'd be able to do away with that wafty crank thing I made for the throttle linkage too. Not sure if the master cylinder would fit though.
| January 29th, 2011, 12:19 pm |
Rhythm Thief wrote: Yes, sort of ... wot I'm trying to do is extend the adjuster barrel because it's the easiest way of extending the cable outer to make an Ami 8 cable fit an Ami 6 with the old type pedal assembly. I've done this by cutting an adjusted off an old cable, but now I need some kind of arrangement to hold it all together. ... I'll post some pictures when I get chance. They're so much better than words.  weld a gearbox mount spacer on the bulkhead or just use cable tension to keep it there? adjust by adding some seatbelt anchor spacers? Sean
| January 29th, 2011, 3:24 pm |
