View unanswered posts | View active topics It is currently April 29th, 2026, 4:09 pm
 Best lube for gear change
Post Re: Best lube for gear change
What could be wrong with a light smear of (conventional) brake fluid - that's rubber-friendly, so I believe (master/wheel cylinder cup rubbers can live with it).
January 21st, 2011, 4:31 am
there are different rubbers
the rubbers in a disky 2cv wont thank you for coming in contact with Dot4
the main thing is to keep it clean and not be tempted to give it a quick squirt of anything
talc, or lock graphite seem to do the trick anything wet just attracts dirt
January 21st, 2011, 10:32 am
Or you'll end up with a rubber that's so swollen up that gear changing is almost impossible
January 21st, 2011, 11:24 am
Spot the female and male in this :lol:
January 21st, 2011, 11:55 am
I reckon it's worth having a can of something like this in the garage: http://cgi.ebay.co.uk/Silicone-Spray-50 ... 4aa561da1b (I don't know about that actual make, but I mean silicone lubricant spray in general.)
I remember from my D&T teaching days buying a can to help release vacuum formed sheets from their moulds - worked a treat. A later project had the kids making wooden mechanical toys - those that were a bit stiff in action - wood-to-wood friction - were helped hugely by this stuff.
The beauty of it is that it dries almost instantly, so doesn't leave any 'wetness', and it reduces friction by a huge amount.
I reckon this might be ideal for your needs, Sam.
January 21st, 2011, 12:35 pm
Yeah - I can go along with the silicone suggestion ... surely that can't do any damage :?:
January 21st, 2011, 1:14 pm
I believe it's a pretty inert substance so won't 'attack' any materials I'm aware of.
Over-spray on paintwork might cause problems if you want to repaint in future?
January 21st, 2011, 9:48 pm
Users browsing this forum: No registered users and 99 guests
