View unanswered posts | View active topics It is currently May 1st, 2026, 11:59 am
 assistence with paint
Post Re: assistence with paint
Just to second the point about hammerited sills. I did hammerite my sills but they're hidden by the running boards so it doesnt matter that they look dreadful :)
January 18th, 2011, 9:25 pm
Sean wrote:
Good
and youll find that Halfords rattle cans of Ford Radiant Red match the wings as well as anything. especially if you spray a drop in the lid and use that with a small brush to touch up stone chips
thanks sean useful stuff
well i want the sills white
i got the paint made up agesa go for new vent flap..
its 2 pack though is that ok ??
January 18th, 2011, 11:46 pm
isn't two-pack pretty poisonous?
January 19th, 2011, 12:21 am
Yup ...contains "Isocyanate" .
http://www.toolboxtopics.com/Gen%20Indu ... Hazard.htm
You're supposed to wear breathing apparatus when spraying it....[and presumably,that does'nt mean a 50pence "facemask" from your local branch of B&Q]
I dunno if the same applies to brush painting it on .....but I would'nt chance it.
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
January 19th, 2011, 1:46 am
T.
You don't need full breathing equipment with modern 2 pack paint. Paint factors will sell masks suitable for 2 pack with carbon filters. The mask has a limited life span and should be used in a reasonably well ventilated environment.
Really no type of paint should be sprayed without an appropriate mask. It gets into your lungs and sets and will stay there for life. The masks are pretty cheap, 15 quid or so, which is less than even a backstreet lung transplant.
January 19th, 2011, 1:57 am
Joe
Posted: Tue Jan 18, 2011 11:07 am
thats the way i look at everything nail..
What ever happened to that tractor battery you were trying to squeeze into your car?
Where's the like button!!!!!! ;)
January 19th, 2011, 2:17 am
twofifty AZU wrote:
You don't need full breathing equipment with modern 2 pack paint. Paint factors will sell masks suitable for 2 pack with carbon filters. The masks are pretty cheap, 15 quid or so, which is less than even a backstreet lung transplant.
So that's 15 quid for you, 15 quid for the wife, the next door neighbours too (either side) and the postman if he's due. Do they do them in animal sizes too I wonder for next door's tabby? ;)
2 pack is seriously shite stuff to use unless you have an isolated garage away from prying noses. Those nice chaps from the environmental health dept also come round with a geiger counter type thing if you are suspected of having used it without meeting their safety criteria. Big fines await.
January 19th, 2011, 11:31 am
D*lly from hell
brush painted sills, and light panel using Halfrauds mixed paint
rear wing in Ford Radiant red
and yes in the foreground is a small tin of hammershite smooth for the wheels
(previously this)
January 19th, 2011, 11:34 am
and isn’t it really toxic if you get it on your skin too? so its a noddy suit for all the above too
January 19th, 2011, 11:38 am
Did you buy a mask for all the neighbours when you painted cellulose?
There are several ways you can damage yourself when painting. 2 pack is nowhere near as dangerous as it was several decades ago as the isocyanates have to a great extent been taken out. Also it isn't just old fashined 2 packs that contain them, even some water based paints have them in. If you get it on your skin it can cause dermatitis and breathing it in causes occupational asthma.
That is not to say that great care shouldn't be taken with 2 pack, but there is a myth that somehow cellulose paint is rather benign. It isn't. Cellulose paint contains organic solvents. These remove natural oils from your skin and also cause dermatitis. Breathing organic solvents affects your liver, kidneys, central nervous system and respiratory system.
Regardless of which paint you spray getting paint dust in your lungs is less than desirable and use a mask. In truth the best advice is probably to get someone else to paint it. I wasn't trying to convice people 2 pack is safe; rather use precautions whatever you spray.
Personally, although I can spray and I can do it well, I tend to send paint jobs out.
January 19th, 2011, 1:30 pm
Users browsing this forum: No registered users and 77 guests
