View unanswered posts | View active topics It is currently May 1st, 2026, 1:13 pm
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3
 Not starting - Petrol supply
Post Re: Not starting - Petrol supply
Much more likely that the short piece of rubber hose, which connects the nylon pipe to the tank unit, is perished.
That hose needs to be a good seal for fuel to be syphoned out of the tank and if it isn't, there will be problems with poor fuel delivery, worse when going uphill.
January 9th, 2011, 8:56 pm
you could try to blow in the fuel filler (make sure no air can escape there, so use a piece of tube and a cloth to seal it). if fuel still doenst run out well, there must be a leak somewhere/
January 9th, 2011, 8:59 pm
Didn't I type a reply out here? That's not here now? I'm such a fucking tool.
January 9th, 2011, 9:02 pm
Oh bollocks, right I'll check the seals again then :roll: Just want it to work now.
January 9th, 2011, 9:06 pm
james2cv wrote:
No it came out as soon as I diconnected it, quite alot but just turned into a drip quickly. Assumed this was normal?
It is normal, so the pipe is most likely not blocked. Do you have different symptoms if the fuel tank is full, half full or near empty?
If so, it can be the little rubber tube connecting the fuel line and the sender unit in the tank. A guy I know, had at problem with his Mehari. When the tank was half full or less, he found that the problem was the suction tube in the sender unit, which had a little hole in it, caused by corrosion, which meant, that the pump was sucking air instead of petrol.
I suffer from citrofilis ..... what's your excuse?
January 9th, 2011, 9:17 pm
Users browsing this forum: No registered users and 101 guests
