View unanswered posts | View active topics It is currently July 4th, 2025, 1:46 am
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 Not starting - Petrol supply
Post Re: Not starting - Petrol supply
Ok just spent another hour trying to start it. Did and checked all that was said above. Even fitted new line from bottom of chassis to carb with new filter. Still nothing coming through. Guessing its the pump then. :(
January 9th, 2011, 5:07 pm
have you poped pipe of card and see if it pisses fuel out? when you crank over it should come out in shots
January 9th, 2011, 7:03 pm
If you disconnect the fuelpipe at the bottom of the chassis, does fuel come out then?
January 9th, 2011, 7:09 pm
Jameswallace wrote:
poped pipe of card
That would definately work. Poping pipes of card are the way forwards! ;)
January 9th, 2011, 7:11 pm
:lol: and yes I did that (without the poping or card) and nothing happens. Also checked the line and disconnected from chassis and yes it was fine. Gonna order a pump later.
January 9th, 2011, 7:16 pm
carb
sorry boys
January 9th, 2011, 7:22 pm
You disconnected the pipe at the chassis under the front wing and no fuel comes out? But it does if you suck?
January 9th, 2011, 7:51 pm
No it came out as soon as I diconnected it, quite alot but just turned into a drip quickly. Assumed this was normal?
January 9th, 2011, 8:37 pm
It needs to run out, no dripping. As long as you keep the end of the fuel line lower than the tank.
January 9th, 2011, 8:44 pm
maybe the gauze (is there one) on the pipe that goes into the tank is blocked
January 9th, 2011, 8:53 pm
Users browsing this forum: No registered users and 70 guests
