View unanswered posts | View active topics It is currently May 1st, 2026, 10:47 am
 Clutch noise when hot.
Post Clutch noise when hot.
I've noticed something odd happening when the car has been used a lot in traffic and is getting hot. When I depress the clutch it emits a funny noise that although not very loud is nevertheless annoying, especially at night when there is less traffic noise to mask it.
Now I come to describing the sound I'm stuck for a reasonable description as it isn't a squeal, or a rumble, in fact it isn't even a single tone but more of a modulated sound. If anyone is old enough to remember the noise they used to make in old flash Gordon films when someone fired a raygun then that's the sort of thing. :lol:
Another way of describing it would be to say that it's the sort of noise I imagine a UFO would make if it were hovering above, but of course if I said that you'd think I was completely barmy. :P
January 2nd, 2011, 3:35 pm
Post Re: Clutch noise when hot.
Clutch release bearing? Though I've heard described more as 'wind through trees' than a ray gun ...
January 2nd, 2011, 3:58 pm
I would also say clutch release bearing. I wouldn't worry about it, it's been making a noise on my 2cv since I bought it in 2002.....130,000 miles ago :lol:
January 2nd, 2011, 4:18 pm
The release bearing is only 3k miles old though. :( The noise is a wheep-wheep-wheep-wheep-wheep type thing that isn't all that loud, just bloody irritating. None of my others have done it, but they all had diaphragm clutches and this one doesn't, would that make any difference?
January 2nd, 2011, 5:01 pm
Correct release bearing for coil spring clutch? I think there is a difference ...
January 2nd, 2011, 5:42 pm
Yep, it came as a kit.
January 2nd, 2011, 6:11 pm
Get a stereo and position one of the speakers right behind the gearbox :D
January 2nd, 2011, 6:20 pm
Sadly doesn't always mean it's the right bits.
Old-Nail,
did you put a dab of grease or some engine oil onto the spigot bearing in the tail of the crankshaft, as well as replacing the tiny oil seal, before fitting the new clutch?
From your description, I'd reckon it's most unlikely to be the release bearing, much more likely that the spigot bearing is dry...
January 2nd, 2011, 6:53 pm
That'll be it then as I didn't put anything on there other than the new oil seal. I saw it was dry on dismantling it so put it back the same way. :roll:
January 3rd, 2011, 12:07 am
