View unanswered posts | View active topics It is currently July 5th, 2025, 4:08 pm
Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3  Next
 Loud screachy Noise from Somewhere!!
Post Re: Loud screachy Noise from Somewhere!!
There has to be a little bearing in the flywheel where the primaer axle of the gearbox goes in, (in a 2cv it is; so it has to be in there too) is it in? and is it in good condition?
December 2nd, 2010, 1:19 pm
In the 2cv it's a brass/bronze (yellow) bush, but it doesn't do anything unless you depress the clutch, the rest of the time the flywheel and gearbox input shaft are 'fixed' together by the clutch.
High pitched squealy noises rarely come from inside an engine, the oil and crankcases seem to damp them out. Noises come from things vibrating, heavy bits of engine don't vibrate fast enough to create high pitched noises, my money's on something relatively light rubbing either on the pulleys at the front or the flywheel at the back.
December 2nd, 2010, 7:25 pm
I've got another one :lol: :lol:
Maybe your toothed wheel from your starter engine doesn't go back in the parked position (it is now rubbing against the flywheel) this gives defintively a screaming sound. Is it the right starter engine for Gs(a)
Well I keep on guessing............ till we fix this...
December 2nd, 2010, 10:06 pm
ive none startes to jam onto the fly wheel (not on a 2cv) and its never made a noise, but then again these starters where mounted vertically as apossed to hoizonally,
December 2nd, 2010, 10:10 pm
I think James is talking outboards again :lol:
December 3rd, 2010, 9:11 am
Ah, is that what they're called these days? In that case, I'm off out to de-ice the cars and, no doubt, freeze my "outboards" off again! ;) :lol:
December 4th, 2010, 9:31 am
:lol: :lol: :lol: :lol: Outboards have horizontal starters :lol: :lol: :lol: :lol
Well funny spanners :lol: :lol: :lol:
December 4th, 2010, 10:21 pm
James mate, have a think about what ya going to write and read it back before you hit enter, Its for ya own Good!! ;) ;)
Will hopefully get closer to the problem 2moro, Going for a clutch related problem, probably have the engine out by the end of the night!!... And hopefully find the problem fingers crossed!!
Dyane 12 1976 (ish)
December 5th, 2010, 10:46 pm
I hope you can localise it and destroy it.................. :lol:
December 5th, 2010, 10:54 pm
Ok, Engine and Box are back out again,and looks like (especially looking at the Pics) The clutch Plate/Pressure Plate has been rubbing on the spring of the Clutch Fork!!!!!!!!
So its looks like it has to of been the wrong Clutch/pressure plate supplied???????
But in removing the lump, I noticed the gearbox input shaft was very wobbly!!..So cracked the front of the gearbox off and the seal was in the depths of the gearbox. Also looks like the shaft itself is slightly bent towards the front!! Bugger!!
Anyone got a spare Engine 1220 or 1299 and a 4 speed box I could have??
Dyane 12 1976 (ish)
December 9th, 2010, 12:48 am
