View unanswered posts | View active topics It is currently May 1st, 2026, 10:47 am
Reply to topic  [ 7 posts ]
 Points
Post Points
What's likely to have caused the untimely demise of the top (fixed) contact of my cars points? I'll Wang a photo up later but the entire contact appears to have burnt away since they were fitted new back in July. Never had a set do that before, I'm assuming something mustve caused it.
December 6th, 2010, 8:58 pm
Post Re: Points
usually the condenser
Aftermarket coil? too much current (not high enough resistance should be 3.5-4Ohms)
too much current voltage reg OK?
and they were Dicellier/valeo ones not inermotor made of chocolate ones?
December 6th, 2010, 9:02 pm
Post Re: Points
Thanks Sean.
Changed condenser anyway, it's got a slightly duff coil and for the first few miles it was overcharging. All bases covered there then...
December 6th, 2010, 9:14 pm
Post Re: Points
my pennys worth
ive always been told by people when you change the points to change the condenser at the same time,
if thats any help
December 7th, 2010, 12:19 am
Post Re: Points
Usually caused by a lack of electron :lol: ic ignition
December 7th, 2010, 12:35 am
Post Re: Points
Yeah yeah, at least I'm only a fiver out of pocket, not £130 that I would be for a busted 123.
December 7th, 2010, 9:12 am
Post Re: Points
must have had a bit of a top end misfire?
or were you putting that down to coil?
PM sent!
December 7th, 2010, 10:20 am
