View unanswered posts | View active topics It is currently April 29th, 2026, 12:38 pm
Reply to topic  [ 85 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
 Battery Cables, + fuel pipe question all in one go
Post Re: Battery Cables, + fuel pipe question all in one go
im seeing my mate in an hour, and he said if it dont fit then he should have it back of me,
my battery just didnt have any punch when starting it, it was totally gutless in the cold, whereas this one in the cold is brilliant,
i managed to move the car into the garage (to fix my fuel pump no fuel issue as it started snowing) on the starter and got wheel spin from it! (needs must..)
December 3rd, 2010, 11:35 am
That's the difference between a shagged battery and a good battery, not between a standard 2cv-size battery and a 2cv-sized battery.
December 3rd, 2010, 11:39 am
If you want a bit more cranking power from your battery, then replace what I assume is a standard 360ah, for a 440ah battery.
December 3rd, 2010, 11:53 am
of the same size!
December 3rd, 2010, 11:56 am
Again, though, it won't provide "more cranking power" - because a healthy 360CCA battery will feed a 2cv starter quite happily.
What it will do is feed it for about 20% longer.
Sean wrote:
of the same size!
the same _physical_ packaging size...
December 3rd, 2010, 11:57 am
of the same spacial shape and volume :lol:
December 3rd, 2010, 1:18 pm
I think we can allow some leeway on mass to go with that on capacity...
December 3rd, 2010, 1:32 pm
ive measured the battery, its about 3/4 of an inch longer than the other battery
December 3rd, 2010, 2:02 pm
7 pages long. Amazing.
December 3rd, 2010, 6:42 pm
Longer than the last battery thread.
December 3rd, 2010, 7:06 pm
