Author |
2CViking
 Re: Odin
Did some adjustments today and bit of welding (gasless juhu) Janez small correction for the bumper holes. I gave you 250.5 mm between the tubes, should have been 255.0 measured from center to center. Used a file and problem solved in a flash, no worries. The AK 400 panel is the same except holes are bigger. Attachment:
AK 400 panel Attachment:
Lining the panels up is good fun, when things fit. Attachment:
One thing I missed was the back panel between the cross box and the rear vertical panel but easy done. Attachment:
Looking forward to spring, only 2 degrees in the garage. IT IS F......G COLD.
November 27th, 2010, 10:18 pm |
petitepoupée
Joined: November 25th, 2010, 6:02 am Posts: 125 Location: Adelaide, South Australia
 Re: Odin
2CViking wrote: Hardly done anything today, bloody customers buying parts all the time  Hi all - as I might have been, in all probability, one of those "bloody customers" I'd just like to say what a great forum this is for a brand-new 2CV owner - and thanks, Peter in particular: a picture is worth a thousand words. Yours have spoken millions! The new shockies arrived just fine, but I discovered in the meantime the rears (Lips) on my car had been installed arse about and upside down. All fixed now, but don't really notice much difference in ride/handling. Saving the new shocks for later, maybe. Am still trying to understand the knife edges - I guess current technology would instead have used "rose (ball) joints". Too cold there? I can recommend South Australia - today is going to be unseasonably cold at 20°C - no rain.
November 27th, 2010, 11:48 pm |
2CViking
 Re: Odin
Thanks mate for the kind words. Mate please ship some Adelaide heat to France, I'm frezzing my balls off. Really miss the Oz weather with summer temps around 40+ degrees. Yes this forum is one of the best. Feel free to ask any questions you like, plenty of opinions here and a sea of knowledge too. This one is reserved for Odin anyway good to see you here, welcome on board. Cheers Viking bastard
November 28th, 2010, 12:18 am |
2CViking
 Re: Odin
Not long to go now for the rear to be finished Attachment:
An UK fellow (local) want to sell me this thing. Lovely to work in front of but move 1 meter away sideway and you don't feel the heat at all. Can't decide to buy it or let it go...!!! Attachment:
November 29th, 2010, 9:01 pm |
petitepoupée
 Re: Odin
2CViking wrote: An UK fellow (local) want to sell me this thing. Lovely to work in front of but move 1 meter away sideway and you don't feel the heat at all. Can't decide to buy it or let it go...!!! Buy two (or three!) - or move to Australia
November 29th, 2010, 11:38 pm |
twofifty AZU
 Re: Odin
Those space heaters are pretty good at throwing some heat into a big space. Unfortunately they also create an awful lot of moisture while doing so because they exhaust into the workspace.
I used to have a wood burning pot bellied stove in the workshop. If you have a ready source of scrap wood it is a brilliant way of heating the workshop. And there were bacon sarnies for lunch........
November 30th, 2010, 12:07 am |
Russell
 Re: Odin
 An hour or two to make, gets so hot the bottle glows red. The way forward.
November 30th, 2010, 12:13 am |
Joined: May 3rd, 2009, 11:40 am Posts: 816 Location: Melbourne, Australia.
 Re: Odin
You should have a cute French girl to snuggle up 2
samfieldhouse wrote: It is M9 for the shocks yes, the rest I'll check when next i'm underneath her. Ironically, this will be valentines day.
November 30th, 2010, 5:48 am |
2CViking
 Re: Odin
Russell wrote:  An hour or two to make, gets so hot the bottle glows red. The way forward. Nice to see some recycled material being use, clever thinking Russ. Harley wrote: You should have a cute French girl to snuggle up 2  Harls, I got one, very hot I may add.
November 30th, 2010, 1:40 pm |
2CViking
 Re: Odin
Winter is over, I can continue work on Odin. Done nothing since Nov, too bloody freezing cold. Thanks to Janez in Slovenia, the rear cross bar is now in place and it fitted nicely, thanks Janez. Working on the side panels now. Bloody reproduction panels do not fit very well. Lining up the rear side panel mating the sparewheel flap is just hard. The sparewheel panel is way off. Had to cut the hinge off and move over the original. The panel was hanging too low so the two lock didn't fit. At the same time, the lock holders are also too big in diameter. The spring didn't have any effect just moving around with no tension on. Had to move over the original holders. What a f...g nightmare fitting these crap reproduction panels. This van MUST be ready for Raid Afrique  Attachment:
April 16th, 2011, 5:38 pm |
