View unanswered posts | View active topics It is currently May 7th, 2026, 12:28 pm
Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 10  Next
 My new car ...
Post Re: My new car ...
Just Googled... now saved in my Bookmarks. Thanks for the info, chaps.
November 11th, 2010, 10:55 pm
Jameswallace wrote:
google him, his email adress is on his site
Cheers. Just emailed him.
November 12th, 2010, 9:02 am
he will definately help you
but please don't quote me on that 250 quid - i wish i had never written that - not good manners!!!! :oops:
good luck
November 12th, 2010, 4:43 pm
good luck
Never mentioned it ... let's see what he comes up with. ;)
November 12th, 2010, 6:45 pm
Right. I seem to have finally managed to get the gear linkage sorted, by bending the link between the lever on the box and the gear slider on the dashboard. It goes into all four gears plus reverse now. I've also managed to cobble a choke cable together, by pulling the one off my Charleston to bits and fitting the outer and inner cables to the Ami cable's mounting which is (all together now) different from the later fittings. The Ami cable was too short to reach the carb on the modern engine.
Here are some pics of the gearbox in its new home. Next job is to bleed the brakes and adjust the handbrake, then I can put tin cowling on the engine, change the clutch and put everything back together.
November 15th, 2010, 7:51 pm
Is that ice on the floor at lower left of the first piccie?
November 15th, 2010, 8:11 pm
Don't forget to drill access hole to the gear box drain plug. If not you'll have hell getting to it later
November 15th, 2010, 8:19 pm
That's the kind of advice that would be perfect in a "Top Tips" thread!
November 15th, 2010, 8:21 pm
Me and my old man both have a hole in the top to aid filling up with gearbox oil. Just be careful where you drill! I tapped the hole and popped a bolt in it, makes life a tad easier.
November 15th, 2010, 8:34 pm
No, it's rubble and soil which is soaking up some spilled gearbox oil from Ms RT's ZX. :oops:
November 15th, 2010, 8:51 pm
Users browsing this forum: No registered users and 379 guests
