View unanswered posts | View active topics It is currently May 1st, 2026, 10:42 am
 Oil light
Post Re: Oil light
its not sufficiantly charging? maybe turn the reg up a bit?
November 7th, 2010, 9:51 pm
Post Re: Oil light
rebel2cv wrote:
Used the voltmeter on the battery already it sits at 11.4 and stays there
So not charging then.
Take the bushes out of the alternator first, much the easiest job to start with.
http://www.ecas2cvparts.co.uk/-c-69_79.html
November 7th, 2010, 9:53 pm
Post Re: Oil light
If there is nothing coming out of the alternator "turning up" the regulator will also produce nothing.
November 7th, 2010, 9:54 pm
Post Re: Oil light
fair enough :)
November 7th, 2010, 9:59 pm
Post Re: Oil light
I'm kinda glad you said that I've been debating wether to pull the alternator off or not, I've only done it nice before for similar reasons that turned out to be brushes
November 7th, 2010, 10:15 pm
Post Re: Oil light
i can only geuss your on your uphone with that error in that word, i hate the predictive text!!
ive got a spare alternator on the shelf btw.. should you need it
November 7th, 2010, 10:16 pm
Post Re: Oil light
rebel,
to check if the regulator is the source of this problem, you can bypass it _temporarily_.
To do that, you can use a length of insulated wire which is long enough to reach between the main terminal on the starter motor and the alternator.
It needs a female blade connector on one end and a crocodile clip on the other end.
Remove the lead which is plugged into the blade connector on the back of the alternator and replace it with that length of wire, connecting the other end to the starter motor with the crocodile clip.
With the engine running and the voltmeter connected between the battery posts, keep watching the voltmeter whilst gradually increasing the engine speed above tickover.
Note that you _must_ return the engine to tickover speed as soon as the voltmeter reading rises above 15 volts.
On the other hand, if the voltmeter stays below 12 volts, the fault lies inside the alternator, only the brushes if you're lucky... :(
November 7th, 2010, 10:27 pm
Post Re: Oil light
ken wrote:
rebel,
answers like that ken is why i continue to think your god when it comes to the world of 2cving
sorry bum lick over!!
November 7th, 2010, 10:31 pm
Post Re: Oil light
creep get back to oggling cher loyd on x factor
November 7th, 2010, 10:36 pm
Post Re: Oil light
James, you do have a way with words!
John Jordan
