View unanswered posts | View active topics It is currently July 3rd, 2025, 12:30 am
Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Periodic dramatic loss in power
Post Re: Periodic dramatic loss in power
Paul,
dare one mention that the 'wet/dry' test won't be as effective on a horizontally opposed engine as it will be on one with vertical cylinders? :roll:
On the other hand, use of a 'leak-down' tester makes it possible to determine exactly where a problem lies, be that with the rings, inlet valve or exhaust valve...
As D.A. has pointed out, an intermittent poor running problem isn't going to be connected with low compression.
When that's gone, it's gone for good, despite what those wonder chemical cures may claim. ;)
November 6th, 2010, 9:37 pm
What's a 'leak-down' test, Ken?
November 6th, 2010, 11:46 pm
In outline...
< http://en.wikipedia.org/wiki/Leak-down_tester >
and in detail...
< http://www.lovehorsepower.com/MR2_Docs/ ... esting.htm >
A compression test is a very blunt instrument in comparison to one of these. ;)
November 6th, 2010, 11:55 pm
i get the idea ken, and i think its a brilliant idea!
November 6th, 2010, 11:56 pm
ken wrote:
Paul,
Depends how you do it Ken. I usually squirt three or four squirts of engine oil in the plug hole, crank the engine for 10 seconds then fit the compression gauge and conduct the second test. At the end of the day the test is only an indicator of why the compression might be low. A strip down will still be necessary but its a good starting point of what to look for.
Now don't you go all Nordic on me, you know it makes sense ;)
November 7th, 2010, 12:08 am
Apologies, seems that genetics dictate I mostly do Celtic... :(
It is possible to make your own leak-down tester and I'm sure once you've realised what an effective tool it is in pinpointing exactly where a problem lies, you would only use a compression tester as a 'first check' instrument.
November 7th, 2010, 2:54 am
Friend of mine had an outboard in to repair, running tough as old boots. Top 2 cylinders, no compression, bottom one tons, his instinct said head gasket, between1 and 2, and he was right, but only confirmed after dismantling engine, would a test like that tell you that in theory ?
November 7th, 2010, 9:47 am
Hi James,yes it would.What you are doing is pressurisng the cylinder with the piston at tdc,so the valves are closed,thus giving you a sealed cylinder.Now,when you pressurise the cylinder,if the gasket has blown between two cylinders,with all the plugs out,you would hear the pressure leaking into the next cylinder.Also,the gauge would show a pressure drop.
November 7th, 2010, 10:02 am
What I had suspected :-) thanks dave
November 7th, 2010, 10:07 am
OOOh yer bacon fed Ulstermen may be spinnin in their graves-Red White and Blue through an through :shock:
Any way back to post 1
id be looking for an electrical problem for this one
had a spark plug and the screw on terminal had come off ans at certain points that cyl cut out
when you stopped to look all seemed ok
November 7th, 2010, 10:45 am
