View unanswered posts | View active topics It is currently June 30th, 2025, 11:07 pm
Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3, 4
 well, erm..
Post Re: well, erm..
Jameswallace wrote:
[i would bloody hope your pulling my leg :roll:
I'd never do that..... :lol:
Check all the earth connections are nice and clean, terminal on the starter motor clean and tight.
October 25th, 2010, 12:26 am
james did it flicker as if there was a loose connection?
or
Did they sort of pulse like a pathetic disco unit?
1 is a loose connection - simple
2 the contacts in the voltage reg need cleaning and ajusting as well as looking at the state of the carbon brushes in the alt.( which also confirm your 15v and short points life)
@ twofifty very unlikley to be loom failure is it? at most a few bad contacts
October 25th, 2010, 7:38 am
option two sir !
i shall check out voltage reg later and clean terminals later, no idea how id go about checking alternator brushes, looking through the gaps it doesnt look clean but i know next to less than nothing about alternators
October 25th, 2010, 9:23 am
Jameswallace wrote:
option two sir !
voltage reg if its an original at the bottom of the black cover thare are 2 plastic pop rivets
press out a little plastic pin from the centre , pull out the rivets and the cover lifts off
you will see a set of points, clean them with a bit of wet and dry paper
you will also see a wheel thing close by usually with 2 holes in it, turning that ajusts the output
i dont bother as ive got an electronic one
you want it to go up to about 14.5vthen hold steady as the revs increase, then come back down again when the revs drop
on the back of the alternator there is typically a couple of screws in the black plastic bit where the small lead goes, thats the brush pack undo the screw(s) and wiggle it out, there should be a fair old bit of carbon brush sticking out. The contact face should be slightly curved and have no step on it, dress it with a file if it does
the copper bit in the alternator should be fairly bright and not too scored.
the front of the alternator where you see the wires shouldnt have any big green pits in it.
plenty on tinterweb about alternators
and thats pretty much you sorted
October 25th, 2010, 7:19 pm
sorted indeed, ill have a go tomorow, i would imagine it is an original, i shall investigate tomrow, am i write in thinking that the whole unit will un clip from wires, and i can have it on the bench to have a proper looksie?
October 25th, 2010, 7:32 pm
yes and alternator best done on the bench too, however it'll all have to be back together to test it.
October 25th, 2010, 7:39 pm
yer, ill take a look at the reg first, is it sort of adjust it, test it, i geuss it cant be done whilest the car is running, ill have a go tomrow
October 25th, 2010, 7:44 pm
you can take the lid off the reg on the bench, clean the contacts. But it will have to go back on the car and then the engine run up and down to test* and make sure its not over charging
make sure that all the wound wire resistors on the underneath are complete and not broken, look to see if there is any broken wire or use your multimeter set to resistance or continuity and touch either end of each resistor
if any are broken you need a new reg
*think that there is a "measure the gap" type of instruction in the first edition of Haynes, not sure if its there in the latest edition
October 25th, 2010, 9:35 pm
Since doing the points and timing, my car seems to be much more efficant!!
Lot less fuel being used!
October 31st, 2010, 10:08 pm
