View unanswered posts | View active topics It is currently July 1st, 2025, 2:42 pm
Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3, 4  Next
 well, erm..
Post Re: well, erm..
Bad..!!
October 24th, 2010, 1:33 pm
so russ's verdict is the points look fine. i did a voltage check, on idle i have about 14.5-13 ISH and revving a bit i get 15.....
no blone up stero yet or egg smell suprisingly :roll:
October 24th, 2010, 6:53 pm
if it goes above 14.5 when you rev it the voltage reg needs turned down
it shold climb steady wirth revs to about 14.5 then hold at that even when you take it up to near full revs
it wont blow stereo because they usually have built in regulation
condensers, indicator clicker and coil may suffer
and as an aside have you been out for a drive yet does it feel any better?
October 24th, 2010, 8:17 pm
how do i turn it down?
yes i have, it feels so much different to drive, i dont think its pinking,
i say its so much better to drive, i havent driven it since friday, and have been driving a boat with heavy steering all weekend, so may just be that but it feels so much better!
i have it about 3/4 tooth ish after firing, couldnt get it spot on so i settled for that!!
October 24th, 2010, 9:05 pm
driving home tonight, and the headlamps flickered every now and again, if i had the interior light on it was noticable, but hardly so with the headlamps,
October 24th, 2010, 11:23 pm
Sounds like wiring loom failure to me, you'll need to replace it :twisted:
October 24th, 2010, 11:30 pm
If thats the case, i dont think i will check posts on this forum for a few weeks :lol:
October 24th, 2010, 11:33 pm
i would bloody hope your pulling my leg :roll:
only just replaced the loom with one kindly given to be my mr rythm thief..
October 24th, 2010, 11:35 pm
oh im not talking an intermitant connection flicker, a sorta' voltage drop and rise flicekr
October 24th, 2010, 11:36 pm
could be all down to how your voltage regulator is working. or how loud you play your spice girls records, or whatever.
October 25th, 2010, 12:22 am
