View unanswered posts | View active topics It is currently April 29th, 2026, 11:36 am
Reply to topic  [ 89 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
 Blue Smoke / Engine flush?
Post Re: Blue Smoke / Engine flush?
Jameswallace wrote:
Ps checked oil this mo, was half way between full and empty, so lost half between the marks if that makes sense :shock: wheres it going?!?!!!!!! No blue smoke though.... And drips on garage floor, but that much?!?!
Build up of mayanoise shit also. But engine hasnt run on for a while. I floored at 40mph luke said and seeme absolutly fine. Going to do timing, hopefully thats all it is. ?
Edit. Better do timing befre flooing it at 40!
wow i cant spell when on my phone, forgot to mention, just after posting this, before i set off on my way, i checked the oil again, the engine was cold, had been left 1.5 hours, and it was at the top mark, wtf?!
October 19th, 2010, 6:24 pm
Sean wrote:
plus you see the plastic bit thats pushed by the cam? that wears quite quickly in the first few hundred miles as it beds in to the cam as it wears it closes the gap and effectivley retards the ignition.
surely? :?:
October 19th, 2010, 6:25 pm
look at the post time i wasnt on my second coffee yet
yes it advances the timing as it wears :oops:
Sxx
October 19th, 2010, 7:43 pm
It's worth checking the points cam and advance weights on an older engine. Relatively cheap and easy to replace, and they do wear out.
October 19th, 2010, 8:29 pm
James Im gettin confused with the constantly changing symptoms,
ok your going to do no harm in setting the points and getting the timing spot on
however now oil consumption is alarming level and the occasional mayo is now a build up in a short while
do the timing when you can then lets see where it goes from that.
if the oil consumption is that high and your gettiong mayo even with the engine getting hot we may have a more serious problem with this engine
October 19th, 2010, 8:49 pm
Head gasket...
October 19th, 2010, 9:08 pm
water pump
October 19th, 2010, 9:21 pm
Sxx
ah no, you did actually write that it will advance as it wears, but surely worn heel = shrinking points gap = retarded ignition?
October 19th, 2010, 9:47 pm
No im only posting what i find to make it clearer, i am pretty sure the timing isnt spot on, as it was done by sound of enine not by rod, so timing i will do soon,
i cant imagine (well hope not) that the engine is fucked, as it shouldnt be at 40.000 miles, also just to make clear, when i checjed oil this mo, no oil, when i checked in afternoon, after hour and half it sitting there, it was cold, tons of oil... Maybe the morning one was a duff reading, bu it had still dropped a tiny bit either way.
How ling a rod do i need and will a headlamp bulb be suitable?
October 19th, 2010, 9:52 pm
James,
I wouldn't let that mate near your engine again, if his idea of 'timing' it involves twiddling the points box around whilst he listens to the engine.
That's a shortcut to a ducked engine, regardless of whether it's done 4,000 miles or 140,000...
i cant imagine (well hope not) that the engine is duck, as it shouldnt be at 40.000 miles, also just to make clear, when i checjed oil this mo, no oil, when i checked in afternoon, after hour and half it sitting there, it was cold, tons of oil... Maybe the morning one was a duff reading, bu it had still dropped a tiny bit either way.
October 19th, 2010, 10:20 pm
