View unanswered posts | View active topics It is currently April 29th, 2026, 1:49 pm
Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 RUST EATER
Post Re: RUST EATER
ooh! Yes please! :)
October 13th, 2010, 8:02 pm
Post Re: RUST EATER
Wot about the original question about rust eaters,any one used any good ones?
October 13th, 2010, 9:39 pm
Post Re: RUST EATER
Sorry, went rather off topic...
I don't have much experience of them, but for what it's worth I have used some green jelly hammerite stuff, which I don't rate very highly. Took ages to do anything, and didn't remove all the rust anyway. (Of course, I might not have prepared it properly or something)
Also I have used the very stuff Neil originally mentioned, which actually worked perfectly. I have only used it the once, because in most places the body is so thin, the rust needs cutting out and new metal welding in. But if it is just chips that need attention, or light surface rust I would have thought it would be just the job.
That's my tup'ence worth anyway :)
October 13th, 2010, 10:09 pm
Post Re: RUST EATER
Thanks neil and gas mark 5,i think i will try some.Will let you know how it goes.
October 13th, 2010, 10:18 pm
Post Re: RUST EATER
ill nip out to the garage in the morning and see what i used before, its brilliant stuff!
October 13th, 2010, 11:58 pm
Post Re: RUST EATER
Smiffy wrote:
I used one of these to strip a door recently. Want me to take some pics and post em up?
I use this... and gas torch to warm color a little . Very good for removing rust and old color.
Before...
After...
www.2cvkeza.com
October 14th, 2010, 8:20 am
Post Re: RUST EATER
Jameswallace wrote:
ive got 2 drill attachments, one huge one ansd a smaller one, but i still think the dremel is the perfect tool (personally speaking) it gets into little gaps that the drill cant, such as inside the boot floor at the bottom of the rear sweep, was a small bubble on inside, now, sorted
i geuss its one of those things, tis like women with what fragerence they where, but with us men its tools :roll: personally i think that the dremel does the job, designed for it or not
Fair enough mate. If it works for you ... :)
October 14th, 2010, 8:22 am
Post Re: RUST EATER
When you say dremel, you're talking about one of those mickey-mouse things with the tiny spinning tools on the end? How long does it take to (for example) strip the paint off of a door? I'd have though it'd take bloody ages? I don't see what's wrong with a 4.5" grinder?
October 14th, 2010, 8:34 am
Post Re: RUST EATER
I think James is talking about dealing with tiny rust bubbles. At least, I hope he is ...
October 14th, 2010, 8:37 am
Post Re: RUST EATER
Yer but i havent had the need to strip a door. (yet) and i find its useful for littlebobscure bits that an angle grinder wouldnt get too
and yes i am !
October 14th, 2010, 8:38 am
