View unanswered posts | View active topics It is currently May 1st, 2026, 10:42 am
Reply to topic  [ 52 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 RUST EATER
Post RUST EATER
I need to buy some rust eater,having never used it before,I would be greatful for some recomendations.
October 12th, 2010, 9:34 pm
Post Re: RUST EATER
Dave,
I rate Bilt Hamber stuff highly - everything i've used from their range seems to be top notch. It always seems to come out on top when tested by the motoring press too.
This could be just the ticket:
http://www.bilthamber.com/deoxgel.html
October 12th, 2010, 9:46 pm
Post Re: RUST EATER
Hi Neil,I have read about this product in Practical Classics,it seems to be a good product but there is nothing like speaking to someone who has actually used it.I dont have a huge amount of rust to treat,stone chips on the bonnet,a few on the doors and thats about it.
I will take your advice onboard and wait to see if anyone has either used it or has any other suggestions.Thanks for the advice. :)
October 12th, 2010, 10:03 pm
Post Re: RUST EATER
i have some very good rust eater, amazing stuff, ill look tomrow and see what its called,
howeber with my new toy (my dremel thing) ive come to just getting the mini grinding disc out and grinding it out :roll:
October 12th, 2010, 10:57 pm
Post Re: RUST EATER
James,because the metal used in the panels is so thin,i would think that it would be best to leave as much on the car as possible.I only have a small amount of rust,mainly stone chips.If using a dremmel be careful not to take to much off or even go through the panel. :(
October 13th, 2010, 7:31 am
Post Re: RUST EATER
Yer your right. Dremel grinding takes a minimal amount away, not anything measurable, so i tend to use it, in hope!!
October 13th, 2010, 11:13 am
Post Re: RUST EATER
Are you actually _grinding_, or are you merely using something like a wire brush to clean back to shiny metal?
October 13th, 2010, 11:57 am
Post Re: RUST EATER
I recommend wire brush for cleaning rusted panels. Than use chemicals ...
www.2cvkeza.com
October 13th, 2010, 2:49 pm
Post Re: RUST EATER
a mini grinding disc on my dremel, it only takes an measurable amount off, but work every time something like this Image
BUT it is a grinding disc, and if your not very careful :roll: im very careful !
October 13th, 2010, 4:14 pm
Post Re: RUST EATER
So, yes, you are removing steel. Use the proper tool for the job, James. Just clean back to a bright metal surface.
October 13th, 2010, 4:16 pm
