View unanswered posts | View active topics It is currently May 1st, 2026, 12:00 pm
 Heavy Duty Battery?
Post Re: Heavy Duty Battery?
When I went to Raid Poronkusema in 2009 I swapped the 2cv battery for the Xsara diesel battery and it was ace at starting the car at -20c. No idea what the amps is but I'll have a look in the morning.
October 7th, 2010, 2:08 am
http://cgi.ebay.co.uk/boat-marine-batte ... 500wt_1154
friend of mine is selling those batterys, hes got a few, if he doesnt sell any, geuss where one may be going if it fits ;)
750 cold cranking amps, and 88ah, should turn the engine a bit ;)
October 8th, 2010, 12:03 am
If that's any heavier than a standard battery you might want to reinforce the bulkhead, they tend to fatigue on later cars.
October 8th, 2010, 8:26 am
mines already cracked, appareltly a piece of wood to supprt the battery works wonders :roll:
October 8th, 2010, 9:40 am
Or what about welding the bulkhead back together and using the reinforcement from an older 2cv?
October 8th, 2010, 5:53 pm
one day, one day!
October 8th, 2010, 9:38 pm
Russell,tell me more about using the older 2cv part.My bulkhead has cracked in 3 places and i need to fix it.I was going to just weld up the cracks,but if a better way is possible and stronger then thats the way to go :)
October 13th, 2010, 7:45 am
Doesn't anyone make weld on bulkhead re-enforcing panels, I'm surprised if not?
October 13th, 2010, 12:10 pm
http://www.ecas2cvparts.co.uk/battery-s ... p-522.html
October 13th, 2010, 12:41 pm
Jonathan wrote:
http://www.ecas2cvparts.co.uk/battery-support-bulkhead-crack-repair-frame-p-522.html
I got one of those last year.
Welded the split up 1st, then treated the metal and painted it up to prevent Mr Rust coming back, then installed the repair frame. Works a treat! Without the frame, the bulkhead's always going to be under a lot of pressure from the weight of the batter, particularly at the point of repair.
October 13th, 2010, 12:49 pm
Users browsing this forum: No registered users and 78 guests
