Smiffy
Joined: October 23rd, 2009, 10:41 pm Posts: 2356 Location: Worcestershire
 Rear end problems. Sensible advice sought.
Just thought I'd have a nice afternoon tidying up the snail's rear end prior to the onset of winter... and had a bit of a shock: Look closely: As viewed from underneath: Worse still, that whole back seam is crunchy, and is just about detached: The rest of the boot well is not bad at all, apart from a couple of little patches as shown here: My rear sweeps are fine (replaced a year or so back) and everything else around the back end is in good nick. So, given this set of circumstances, what would you do? I don't want to spend a fortune, but I'd like to nip the problem in the bud. Cheers.
| October 10th, 2010, 3:25 pm |
Russell
 Re: Rear end problems. Sensible advice sought.
I would change the boot floor and back panel. Might be possible to avoid redoing the rear sweeps depending how they were fitted last time.
| October 10th, 2010, 4:52 pm |
602
Joined: July 21st, 2010, 7:12 pm Posts: 859 Location: Chatenet, France
Russells right. Boot floor is not an expensive panel. Will make the back end very tidy and water tight.
| October 10th, 2010, 6:25 pm |
twofifty AZU
It's only metal; weld it up. I'm fairly sure I have a new genuine lamp panel somewhere, and a pattern boot floor.
| October 10th, 2010, 6:28 pm |
J-dub
was it one of those moments where you havent looked in the boot for about 4 months? i did that after painting the por 15 in there, then i realised the boot was leaking, so every time it rained there would be a puddle in the boot, so i went over the por15 with red oxide. sorry for the moment of irelevantness,
| October 10th, 2010, 6:58 pm |
Smiffy
Jameswallace wrote: was it one of those moments where you havent looked in the boot for about 4 months? i did that after painting the por 15 in there, then i realised the boot was leaking, so every time it rained there would be a puddle in the boot, so i went over the por15 with red oxide. sorry for the moment of irelevantness, Yes it was a bit of a moment like that. I've been looking forward to a nice sunny Sunday for a while so that I could just potter around the snail. There was me saying to myself "I'll just get those bumpers off and tidy them up... oh and while I'm at it I'll have a quick look at that crunchy bit I noticed under the rear seam and... DOH!
| October 10th, 2010, 7:16 pm |
J-dub
i can just picture it!!
i hate moments like that!! ive been working today as it wa very hot, on very small tiny bits of rust starting to show, such as top of b post etc,
and i decided to re do the sealent between bonnet hinge and bulkhead, and just happily getting the old stuff out, as you do, and boom, my chisel thing went through the bulkhead! doh, wouldnt be so bad if you couldnt tell id done it! well you can hardly tell, it was going to go anyway! so ive put that dum dum stuff in there, let it go off, looks good, !
anyway hope you get it sorted!
| October 10th, 2010, 7:24 pm |
Smiffy
twofifty AZU wrote: It's only metal; weld it up. I'm fairly sure I have a new genuine lamp panel somewhere, and a pattern boot floor. If you find them, please let me know. It'll be good to get this sorted out before the weather turns horrid. Cheers.
| October 10th, 2010, 8:37 pm |
