View unanswered posts | View active topics It is currently April 29th, 2026, 11:35 am
Reply to topic  [ 4 posts ]
 Headlining...a question for those with a metal roof!!
Post Headlining...a question for those with a metal roof!!
Hello there
before it gets too chilly and i have condensation raining on me....i want to re-attach the headlining on my Ami 6. The original foam has long since blown away into the wind and all that is left is the plasticy perforated 'sheet' - it's not torn, so wnat to re-use it....
question is - what should i use to 'back' the perforated sheet (foam? material?) and what adhesives should i use...any advice etc. etc.
Thanks
Will
September 28th, 2010, 4:04 pm
Post Re: Headlining...a question for those with a metal roof!!
Willami wrote:
Hello there
I used the underlining you use for a laminate floor. Thin enough to do a job, and thin enough to stay put.
Used a strong spray mount adhesive. It will be easier in an ami though as its a flat surface. The van was a nightmare!
September 28th, 2010, 5:49 pm
An ami roof isn't a flat surface dude!
September 28th, 2010, 7:21 pm
Thanks Max....Russ, I am right in thinking you used jazz mags for yours??? :lol:
September 29th, 2010, 1:51 pm
