View unanswered posts | View active topics It is currently April 29th, 2026, 10:00 am
Reply to topic  [ 7 posts ]
 recommend me some drill bits for 2CV metal
Post recommend me some drill bits for 2CV metal
Hi
It's time I invested in some drill bits - purely for metalwork, ali and steel - any metal on an A-Series.....
1mm upto 15mm??? what would the range be??
don't really want to spend more than £20 / £25.....have a good Swiss Bosch drill for them to go in....
any thoughts - thanks
Will
September 2nd, 2010, 1:08 pm
Post Re: recommend me some drill bits for 2CV metal
I picked up a good set housed in one of those folding metal boxes ages ago from ALDI for about a fiver and I'm still using them.
The range is from .5mm - 12mm but I've also got an incremental conical bit (not sure of it's correct name) from 4-20mm in 2mm steps
September 2nd, 2010, 1:58 pm
Snap
the aldi were a good buy if a little brittle
the sheet metal stepped bit is ideal for bodywork again Aldi and about 1/3 the machine mart etc prices
i also buy a jobber set of 6mm from toolstation to drill out spotwelds
clicky
September 2nd, 2010, 6:15 pm
For such thin bodywork metal (yes, I'm talking 2CV), is it worth also having a tapered reamer in your 'kit?
Drilling larger holes in this kind of metal can be a real pain if you can't support the panel properly, and the drill can also 'grab' and distort the panel. A smaller drilled hole followed by a reamer might just be the job?
September 3rd, 2010, 11:38 am
great - (frantically googles "tapered reamer") ha ha
i shall do some homework - seems i don't need to spend much over a tenner....nice
thanks all
Will
September 3rd, 2010, 11:50 am
:D
September 3rd, 2010, 11:10 pm
I must admit, I thought it was rather a strange question to be asking at first. I've always regarded drill bits as a disposable/expendable/consumable tool so I get them as & when I can. I know there are different types & materials so some may blunt or break sooner than others but in this instance I don't use the "cost versus durability" formulae.
September 4th, 2010, 1:11 am
Users browsing this forum: Google [Bot] and 36 guests
