View unanswered posts | View active topics It is currently June 29th, 2025, 4:27 am
 Gear box pinion circlip
Post Gear box pinion circlip
Looking for an UK mob to produce these circlips in spring steel. This one is mild steel and can not be reused.
Any help is much appreciated
August 4th, 2010, 12:37 pm
Post Re: Gear box pinion circlip
I'd be very surprised if those need reproducing, they're generally used in standard sizes. However that isn't a circlip, that is a snap ring or Eaton ring. It should be available off the shelf.
August 4th, 2010, 10:27 pm
It is but look at this price
http://www.mehariclub.com/segment--a--1013715.html
I have plenty old ones but not usable. They expand and don't bounce back
August 4th, 2010, 10:32 pm
http://lmgtfy.com/?q=snap+ring%2Beaton
August 5th, 2010, 1:42 am
Viking,
any chance you can put the vernier on it and give us a few critical dimentions
August 5th, 2010, 7:45 am
Sean wrote:
Viking,
Thickness, well the old vary from 2.30-2.40-2.50 mm. 2.50 mm would be new, no wear. The groove in the pinion is max 2.80 mm wide.
Outside diameter 36.25 mm measured on one ring still on the pinion. The removed rings are much bigger in diameter.
Inside diameter. Can't measure correctly but groove on the pinion is 27.80 mm
August 5th, 2010, 10:22 am
Thanks for the link. Can't find the ring I need. I wonder if any in the UK would have the same rings for sale. The link is for an US firm, most likely impossible to deal with.
Cheers
Viking
August 6th, 2010, 11:24 am
had a look last night but cant seem to find any of the right thickness yet
for what its worth they seem to like the dimention of the shaft (guessed at 30mm) that the groove is in rather than the diameter of the base of the groove.
ill have another trawl about later
sean
August 6th, 2010, 7:40 pm
2CVIKING
If you want help contacting a US company send me the info and I can contact them next week for you.
Jason
August 7th, 2010, 1:57 am
2Cvcruiser wrote:
2CVIKING
Jason
Thanks Jason for your kind offer. Lets see if they can be found in the UK, if not I shall return
Cheers
Peter
August 7th, 2010, 10:32 am
