View unanswered posts | View active topics It is currently April 29th, 2026, 6:25 am
Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Hot smell on hills
Post Re: Hot smell on hills
When you're horsing the engine up a hill, is there any hint of the revs going up without a corresponding increase in road speed - ie: clutch slip? That makes a bit of a stink, I understand - an acrid, musty pooey smell...
July 21st, 2010, 9:28 am
Thanks for the suggestion, but nope. It doesn't smell like a slipping clutch either. It does smell like metal getting hot.
July 21st, 2010, 9:29 am
over heating slightly? maybe something metal on part of the engine, when at a certain angle, fi that makes sense
July 21st, 2010, 11:42 pm
Enough oil in the gearbox, engine oil cooler nice and clean?
July 21st, 2010, 11:59 pm
spilt oil from oil change running down engine to hot part as a result of the change of angle of the car? wild one!
July 22nd, 2010, 12:07 am
could just be the smell of a hot engine :?
something that modern motorists have very little experience of in their climate controlled hermetically sealed box
July 22nd, 2010, 7:38 am
Jono,
when you mention going 'slowly' up hills, would that be at around 35mph in 3rd or 50mph in 4th, with wide open throttle?
Those speeds correspond to the engine's peak torque, so would produce higher instantaneous cylinder pressures than at any other point in the usable rev range.
_If_ the seals between the barrels and heads had been compromised at any time in the engine's history, then that's when there'd be most tendency for the joints to start leaking again, even if only slightly...
The method of checking would be to block off the heater intake stubs completely (making sure that the heat escape flaps and tubes were set correctly), then try a few hills under the conditions mentioned earlier.
July 22nd, 2010, 11:37 am
Probably! It's just that it's only just started smelling like this - if it always had done I'd think nothing of it.
July 22nd, 2010, 11:38 am
Users browsing this forum: Google [Bot] and 85 guests
