View unanswered posts | View active topics It is currently April 29th, 2026, 8:58 am
Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Help me out, I've been a bit of a dick.
Post Re: Help me out, I've been a bit of a dick.
toomany2cvs wrote:
[Fix the resistor between the two terminals, and connect the rest up as normal.
I thought it had to be in SERIES to drop 6V, otherwise you're going to have 12v across both the resistor & gauge. This is assuming the gauge is actually a voltmeter & not an ammeter, in which case the parallel arrangement is correct.
July 16th, 2010, 7:31 pm
Did I ever claim to be fluent in Norwegian?
July 16th, 2010, 7:34 pm
As much as I really do appreciate help and guidance, you might aswell have babelfished this into Norwegian for the amount i understand!
Your Mother was a hamster & your father smelt of elderberries :lol:
Hopefully that diagram with the resistor & the 6v dropped across it and the meter might clarify things Russ?
July 16th, 2010, 7:38 pm
You've met them, then?
July 16th, 2010, 7:43 pm
Just to recap, The wiper switch, I can sack off one wire to do away with the park thing then it'll work off me new switch. Which two wires should I connect?
July 16th, 2010, 7:51 pm
I think white is park. Try it and see.
July 16th, 2010, 7:55 pm
Thanks. It's only three wires innit? what's the worst that could happen?
July 16th, 2010, 8:14 pm
the worst? a blown fuse ;)
just try.
don't know wich wire I didn't use.
July 16th, 2010, 8:33 pm
I've got a reconditioned 425 engine complete with dynamo, carb and starter motor and gearbox; just convert the whole damn car to 6 volts.....
I'll get me coat :lol:
July 16th, 2010, 8:37 pm
I'd find that less confusing, but I think if it came to that I'd just use the standard speedo... :lol:
(Thanks, BTW!)
July 16th, 2010, 8:39 pm
