View unanswered posts | View active topics It is currently June 19th, 2026, 8:24 am
 Citroen GS Tachometer
Online
Post Citroen GS Tachometer
Has anybody used a Citroen GS Tachometer (Round Analogue) on an A Series.
Can you share the wiring information.?
March 30th, 2009, 11:56 am
Post Re: Citroen GS Tachometer
Not too sure of this, but...would a four cylinder rev-counter work on a two cylinder engine and be accurate? Unless the car in question has a GS engine, then my question is redundant ;)
March 30th, 2009, 1:14 pm
gym bunny
Neil had one converted at cost IIRC and used it in his Dyane ok. I bought one form eBay for a Harley for the Ami (602cc) and that works fine. All depends what you want it for or to do.
1299cc FTW
March 30th, 2009, 7:21 pm
Online
Need the connections, What goes where?
March 30th, 2009, 7:28 pm
One to an ignition live, one to the coil's switched earth, one to the light switch for illumination, IIRC.
A G tacho needs to be tickled inside to work, else it'll read wrongly. I _think_ it's a resister swap, but... <shrug>
March 30th, 2009, 9:12 pm
scared of the dark
Yes, its a resister swap, but i cant remember if its value is 200% of original or 50% of original. Ive also heard various rumours that it doesnt actually work acurately when its done either...
Andy M :)
Some previous cars:
March 30th, 2009, 11:20 pm
I had one, years back, in my first 2cv. Worked fine.
The supplier who I got it from is still in business, but I don't think they supply converted G tachos any more - they used to be a catalogue item. Perhaps, Andy, you could ask your employer tomorrow if he remembers what he did with them...? <g>
March 30th, 2009, 11:24 pm
How do you know?
March 30th, 2009, 11:32 pm
How do you know?
Hmmm. Good point... <grin>
Let's put it this way - 800rpm was a nice even idle speed, and it was running out of power north of 5500-6000.
March 30th, 2009, 11:36 pm
I guess I can go really anal here and put my penny worth in.
If you have a Sad-Naff(sorry,I do), they are accurate(something to do with trigonometry :oops: ...I believe). The gear-ratio of 4th gives something like 13mph per 1000rpm. At 65mph, you should be reading 5000rpm or there abouts. So with a sad-naff reading of 65mph, see if the rev-counter tallies, if it does, then the other ratios(gears) should match, giving accurate readings through the range......hopefully ;)
March 31st, 2009, 1:01 pm
Users browsing this forum: No registered users and 217 guests
