JRW_91
lovin' the snatch
Joined: January 27th, 2009, 8:10 pm Posts: 1289 Location: Northampton
 Re: headlights fault!?
LOL
 |-|-' 602 For Life
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6 1986 Sunrise Red 2cv6 1989 Vert Bamboo 2cv6 D*lly (in bits)
| February 22nd, 2010, 10:27 pm |
Old-Nail
ken wrote: If the rest of the dim-dip wiring is still as it was when it left the factory, the side light contact in the light switch needs to carry around 125 watts, or 140 watts if you've got halogen bulbs fitted. With that load, it's just a matter of time before the switch overheats and fails... ken. With dim dip now disabled as per instructions is it safe to use halogen bulbs with no further mods?
| February 24th, 2010, 10:48 pm |
samfieldhouse
I do, although I would recommend fitting relays under the bonnet.
But as I say, after 4 years of halogen bulbs, no problems yet.
| February 24th, 2010, 10:59 pm |
There seem to be plenty of cars running around with 55/60 watt halogen bulbs fitted, so as long as the switch hasn't suffered too much from the time it had to cope with dim-dip... Other folk have fitted relays to remove all but the switching current from the light switch, which is probably the ideal. Since Dyane light switches are made of sterner stuff, it's not something I've ever needed to do. ken Old-Nail wrote: With dim dip now disabled as per instructions is it safe to use halogen bulbs with no further mods?
| February 24th, 2010, 11:03 pm |
terpineol
Having decided its finally time to do this I've stuck the car up in the air to find the sodding resistor is invisible. Any hints as to where it might be hiding?
| July 14th, 2010, 2:54 pm |
toomany2cvs
terpineol wrote: Having decided its finally time to do this I've stuck the car up in the air to find the sodding resistor is invisible. Any hints as to where it might be hiding? In a bin somewhere, hopefully. The resistor was originally clipped to the front of the chassis, between the bonnet catch and one leg of the light bar. If yours was a dim-dip car, there's probably a spare bit of loom dangling down one light-bar leg ending in a multiplug.
| July 14th, 2010, 4:46 pm |
terpineol
toomany2cvs wrote: terpineol wrote: Having decided its finally time to do this I've stuck the car up in the air to find the sodding resistor is invisible. Any hints as to where it might be hiding? In a bin somewhere, hopefully. The resistor was originally clipped to the front of the chassis, between the bonnet catch and one leg of the light bar. If yours was a dim-dip car, there's probably a spare bit of loom dangling down one light-bar leg ending in a multiplug. It had the relays which it needed connected in order for the lights to work, but no sign of any resistor or extra wires around there. I've bridged the relay terminals as instructed though and it all now seems to work nicely.
| July 14th, 2010, 6:14 pm |
J-dub
is that at the bottom rightish of the fan?
the thing you say to throw away? (dim dip) what does it do (stupid but just wondering!)
| July 15th, 2010, 12:32 am |
Jonathan
Back in the '80s, it was decided by "The Powers that Be" that all new cars must be fitted with Dim-Dip. The system works by illuminating the dip beam bulbs by 1/6th, when sidelights are turned on, so when the car is in use with sidelights on, the dip beam is working at a dimmer level to normal. The system was scrapped some years later, so more modern cars aren't fitted with it.
| July 15th, 2010, 12:47 am |
J-dub
ahh
how could i tell?
| July 15th, 2010, 12:50 am |
Users browsing this forum: No registered users and 28 guests |
