View unanswered posts | View active topics It is currently May 1st, 2026, 10:47 am
Reply to topic  [ 9 posts ]
 oil leak
Post oil leak
It appears I have an oil leak :( I had the engine and gearbox steam cleaned week before last, and now there is a light coloured film covering the top of the gearbox, with a different kind of smell to usual engine oil. Is it gearbox oil? The rubber gaiter round the gear leaver is loose, but I've been told that it's more of a dust/dirt cover than a plug. Thanks in advance :)
July 14th, 2010, 12:00 am
Post Re: oil leak
Jonathan,
if you have a good close look at the gearbox lid, near the front end, you'll find a tiny drilling.
That 1mm? hole is the gearbox breather and the reason for the oily film on the lid...
( p.s. it's also one of the reasons why I'd advise changing the gearbox oil after a steam cleaning or pressure washing session.)
July 14th, 2010, 12:41 am
Post Re: oil leak
Thanks Ken, will take a look tomorrow :)
July 14th, 2010, 12:51 am
Post Re: oil leak
Ooo, what do I do? Do I prod it with a stick, or something? :? I'm guessing I need to unblock the hole with a pin, or similar.
July 14th, 2010, 1:18 am
Post Re: oil leak
If there's oil on the top cover, the breather is working as intended, n'est-ce pas? ;)
Maybe worth checking that the gearbox isn't over-filled, though.
July 14th, 2010, 1:29 am
Post Re: oil leak
Many gear box lids don't have this little breathing hole but the air is ''pushed'' passed the gear lever rod. They still sweat a fraction, quite normal.
July 14th, 2010, 9:42 am
Post Re: oil leak
Cheers guys, I don't think it's over full, but there's quite a covering on the lid, more than I would expect for around 1000miles of use. I'll take a look sometime today. :)
July 14th, 2010, 10:37 am
Post Re: oil leak
Any chance of a photo?
July 14th, 2010, 10:40 am
Post Re: oil leak
I'll try and sort a photo later. :)
July 14th, 2010, 11:35 am
