View unanswered posts | View active topics It is currently June 28th, 2025, 2:37 pm
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 headlight bulbs
Post headlight bulbs
so i was talking to matt yesterday, and he said some 2cv's cant cope with the load of the halogen headlamp bulbs, as the wire isnt thick enough. well i felt the back of my lheadlight switch, felt a bit warm, bearing in mind i only have one hal light in atm as one arrived broken, but anyway so im running with od headlamps and i know i shouldnt but thats the way life is sometimes..
and matt was saying some late cars are ok and some arent
mine is an e reg 1988
July 14th, 2010, 12:45 am
Post Re: headlight bulbs
Hot headlamp switch is caused by the dim-dip system....Remove it (He says, even though it's still in situ on his car :oops: ) :lol:
PS:- there are threads devoted to the removal/disabling of dim-dip, here somewhere.
July 14th, 2010, 12:56 am
Here.....
viewtopic.php?f=7&t=1361&start=30
July 14th, 2010, 12:59 am
ok thanks
also,
im wanting to wire in some full beam low beam lights... ideas?
July 15th, 2010, 12:35 am
You've already got 'em, they're called headlights. ;)
July 15th, 2010, 12:41 am
pipe down..
i mean, lights as in like, erm, led lights u know, the blue and green ones...!
what is the dim dip bit all about, about removing it?
confused.com!
July 15th, 2010, 12:42 am
Here you go james,
http://www.2cvstuff.com/Files/DIM-DIP.pdf
Personally I find the haynes diagram easier to follow.
July 15th, 2010, 2:07 am
Jameswallace wrote:
pipe down..
confused.com!
what? warning lights? im with Jonothan. i honestly thought you hadn't worked the switch out.
July 15th, 2010, 2:12 am
Jameswallace wrote:
pipe down..
Do you really want to look like every Audi/Chav tosser on the road :cry: ? You've already got a car that stands out from the crowd - appreciate it for what it is! 8-)
I found the full diagram invaluable when I rewired the Bedouin from scratch compared to the Haynes manual.
July 15th, 2010, 3:11 am
like lights on the dash, small lights, so you know what beam your on easier, i know its stupid..
July 15th, 2010, 9:07 am
