View unanswered posts | View active topics It is currently April 29th, 2026, 10:00 am
 Crankcase pressure valve
Post Crankcase pressure valve
Simple question: Are these worth the money?: http://www.ecas2cvparts.co.uk/valve-cra ... -1401.html
Or should I just get a new breather?
July 12th, 2010, 9:53 pm
Post Re: Crankcase pressure valve
And can someone explain to me, please, how the breather actually works?! When I look through a removed one, I can see right through - no flaps or obvious valves in there. So how does it help contribute to the crankcase vacuum - and how can it become 'faulty'?!
James, there are a few threads on here about crankcase vacuum and how to check it with a home-made gauge which you might find interesting. If you do a search through the 'Technical' section for 'manometer' you'll find a few.
July 13th, 2010, 10:46 am
Look here
http://www.pp-2cv.be/FR/News/kit%20repa ... flard.html
No system can cope if/when piston rings are worn allowing compression to reach the crankcase. Do a compression test first and maybe fit new piston/barrel set.
July 13th, 2010, 11:25 am
Maybe this translation link is working
http://translate.google.co.uk/translate ... =&ie=UTF-8
July 13th, 2010, 12:11 pm
One more
July 13th, 2010, 12:13 pm
Thanks, Viking - that link was both informative and amusing :D
July 13th, 2010, 2:28 pm
Just removed my breather (oil filler tube) to get access to the carb. While it was off, I thought I'd try sucking and blowing through the attached air filter pipe to see if this would indicate the condition of the valves inside...
Ok, I can both suck and blow no problem (keep your dirty comments to yourselves, ta much...)
So, does this suggest - as I fear - that my breather is kaput?
If so, has anyone tried the alternative solution of fitting a one-way valve in the pipe to the air filter instead of replacing the whole breather?
Thanks.
August 26th, 2010, 6:33 pm
1 even a good breather allows you to suck and blow
2 there was discussion at lenght about a boat bilge/shower valve on here some time back or you can get a big foofoovalve from the usually recomended supplier
ya pays yer money ya takes yer chances.
August 26th, 2010, 6:54 pm
Thanks, Sean.
Ah, so the valve isn't completely one-way?! How the 'ell does it work, then? :?
I've looked at the nice ecas valve, and also recall the post you were referring to - I'll have to track it down again and see if it has been updated: ie, has anyone actually TRIED the valve!
Cheers.
August 26th, 2010, 9:15 pm
viewtopic.php?f=7&t=1228&hilit=crankcase&start=20
So, no conclusion!
Dammit, I'm goin' to get one if I can find it...
August 26th, 2010, 9:57 pm
Users browsing this forum: Google [Bot] and 36 guests
