View unanswered posts | View active topics It is currently August 16th, 2025, 12:05 pm
Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 Towing with a 2cv?
Post Re: Towing with a 2cv?
make a strong roof rack get a fork lift and put it on top. :lol:
July 12th, 2010, 7:59 am
Old Bloke
Joolz, there is no way on earth you are going to hang that on the back of a 2cv and be able to drive it properly. Give it up and get a trailer.
Now known as 602
http://www.2CVTech.co.uk
July 12th, 2010, 8:09 am
Quite.
What's it weigh? 150kg? Even on "proper" towbars on "proper" cars, maximum noseweight is nowhere near that high.
July 12th, 2010, 8:34 am
toomany2cvs wrote:
Quite.
Joolz wrote:
it's about 190kg the same as a couple of fat blokes
July 12th, 2010, 8:38 am
Old Bloke
[/quote]
A couple of fat blokes hanging right past the back bumper. Just wouldn't work [unless you were slim like me]
Now known as 602
July 12th, 2010, 8:42 am
toomany2cvs wrote:
Quite.
<points to time stamp on post>
July 12th, 2010, 8:47 am
Personally I don't like being told I can't do something or that it's too dangerous, so I'd have a go at fitting it in the body even if it meant cutting the roof bars out temporarily. Trailering is a pita because you're meant to conform to unrealistic speed limits and trailers will undoubtedly increase fuel consumption.
Otoh, if you're sure you want to tow it, the h frame towbars are what are fitted to my old yellow car, and that's on the same chassis as yours. From what I recall there are some plates above the chassis and it's held on with the bassist sandwiched between the towbar and the plates. I think. Personally I'd sooner make up a couple of tubular crossmembers and bolt them through the two rear legs and mount my towing hitch onto them.
July 12th, 2010, 8:49 am
toomany2cvs wrote:
toomany2cvs wrote:
Quite.
do what?
July 12th, 2010, 8:50 am
Old Bloke
All such wise words Joolz, go for it.
Now known as 602
July 12th, 2010, 8:53 am
do what?
"Yeh, yeh, I missed that bit - it's early..."
July 12th, 2010, 9:02 am
