View unanswered posts | View active topics It is currently April 29th, 2026, 3:58 am
 tie rod adjuster tool.
Post tie rod adjuster tool.
Does anyone have one i can borrow/buy? ecas is out of stock and some other suppliers seem to think they can charge 40% more for the same tool!
July 5th, 2010, 7:45 pm
Post Re: tie rod adjuster tool.
a 9mm (iirc) spanner on the flats of the rod should do the trick.
July 5th, 2010, 7:58 pm
its such a pain in that ass to do it with one though. i guess its sort of worth taking a bit more time and saving 15 bucks. maybe....
July 5th, 2010, 8:00 pm
the proper 'tool' is a pita too - although it does make it a bit easier. i think spanners had some home brewed device that incorporated a ratchet. That was some bit o'kit. :)
July 5th, 2010, 8:03 pm
what about cutting a tie rod sized chunk out of the ring (oo errr) on a 9mm spanner? that might give a bit more contact on the flats?
July 5th, 2010, 8:04 pm
Best to unscrew the rods from the end piece, clean the threads up & copaslip 'em. Then adjusting the heights is a joy to do.
July 5th, 2010, 8:05 pm
i know that that is the correct way to do it.but i dont want to find that i need to replace the knife edges too. out of sight and all that. (im pretty low on cash right now, i need to stop/cut down on boozing)
Neil, how much did that bit of 38mm? exhaust pipe you got for tha acad cost you? i need to get a bit about the same length as the torpedo silencer that i have removed, i cant actually hear myself thing in the car at the moment. but it does sound bad ass.
July 5th, 2010, 8:09 pm
Whoa there Neil, Spanners has got the genuine Citroen tie-rod adjuster tool! :ugeek:
Joe, if you're willing to travel to Birmingham, you can borrow it. Unfortunately I don't trust the postal service so am unwilling to post it to you to borrow. :(
Sorry mate.
July 5th, 2010, 8:10 pm
Sorry mate.
thanks for the offer mate, for the petrol cost i might aswell buy one/deal with taking the tie rod ends off or using a 9mm spanner.
(i dont blame you about the post at all!)
July 5th, 2010, 8:12 pm
The big hexagon with a 9mm slot? I think I have one. PM your address. If I do, maybe payment is the promise that you'll share it about with anyone that needs one? Sound fair?
July 5th, 2010, 8:20 pm
