View unanswered posts | View active topics It is currently August 16th, 2025, 12:12 pm
Reply to topic  [ 9 posts ]
 vent flap + seal
Post vent flap + seal
i was talking to someone at L 2 B (all those moons ago now!) who said that someone supplied a aftermarket vent flap and seal, different to the original design, that doesnt leak.
and as my vent flap is as straight as a roundabout i think i shuold treat the car to a new one (considering it only stays dry if u really clamp it down and grease everything! (like in my post)
anyway does anyone have any ideas where this may be? or anything similar?
July 5th, 2010, 6:05 pm
Post Re: vent flap + seal
mine doesn't leak. if you have a straight vent flap and a new seal it should be fine.....
July 5th, 2010, 6:15 pm
hmmm
is yours an orivinal or pattern
debating whether to spend an extra 20£ on a original or not...
July 5th, 2010, 6:17 pm
original as far as i know. could do with replacing soon as some spots of rust are appearing in the corner. probably go for a stainless one myself.
July 5th, 2010, 6:19 pm
stainless is harder to paint isnt it?
yer ecas says they reccomend not painting!
id rather have one that is the same colour as the car, but im picky!
July 5th, 2010, 6:22 pm
you can use acid etch primer to paint stainless. (i believe)
July 5th, 2010, 7:03 pm
i shall go and see my local paint guy and see which is cheaper to paint
my car lives under cover and when its not in the garage parked else where i put the cover on
so my vent flap shouldnt rust to quick :geek:
July 5th, 2010, 7:22 pm
I have an original one, and it doesn't leak. Use no grease or sealer at all. Just see to it that before it is mounted to the car, it's a good idea to bend it slightly in a curve. (If on the table with outer side up, it must have a curve with the middle part being the highest) This is to get a bit more pressure on the edges. If it has the curve the wrong way I guess there will be a chance for a leakage. (Needless to say, you should change the rubber at the same time you change the flap)
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
July 5th, 2010, 7:31 pm
well mine is horrific,
the left side when closed the right side has about 9mm gap!!
im going to buy the kit, lay it on a table and see whats what, if its flat ill just leave it flat, i may consider bending the two edges in a tad..
July 5th, 2010, 8:33 pm
