View unanswered posts | View active topics It is currently August 13th, 2025, 7:03 am
Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Goodwood Breakfast Sunday June 27th, Nr Chichester
Post Re: Goodwood Breakfast Sunday June 27th, Nr Chichester
I find they don't drive properly until you remove all the bump stops.
June 27th, 2010, 1:16 am
:lol:
I find they don't drive properly until you remove all the bump stops, as contact between road and chassis will limit suspension movement...
June 27th, 2010, 10:48 am
Exactly. Axle bolts are a 300 mile service part now.
June 27th, 2010, 10:50 am
Russell,
reckon you need to knock up some skid plates at work, maybe some 20mm x 3mm flat with a length of 20mm bar welded along one edge.
I fitted something similar on a race chassis once, after noticing that the bolt heads had worn wafer thin following rather a lot of contact with the rumble strips.
They'd extend the service interval considerably... ;)
June 27th, 2010, 11:06 am
I seem to recall Russ admiring something similar on a certain red BMW-powered Spesh at Giel.
June 27th, 2010, 11:13 am
Harry and I had a discussion about this the other week. I'm going to try and make something up at work from a bit of box section cut about a bit. The difficulty of course, is if you make the protection too thick, it impedes how low you can run.
Anyway, where are the pictures from Goodwood?
June 27th, 2010, 12:11 pm
goodwood was good
me and mr vent flaps had a race around a gokart track :lol:
June 27th, 2010, 7:15 pm
June 27th, 2010, 8:55 pm
Skid plates? You'll be thinking of these;
http://i686.photobucket.com/albums/vv22 ... C00179.jpg
http://i686.photobucket.com/albums/vv22 ... C00181.jpg
25mm box in an attempt to protect the fromey shock mounts.
June 27th, 2010, 11:21 pm
if thats your car
looks very clean underneath
especially the shocks
June 27th, 2010, 11:26 pm
Users browsing this forum: No registered users and 18 guests
