View unanswered posts | View active topics It is currently April 29th, 2026, 3:51 am
Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
 Strange honky-parpy noise (left-rear) when going over bumps
Post Strange honky-parpy noise (left-rear) when going over bumps
Pretty much as it says in the heading, really. I'm being a lazy git tonight, so I can't be bothered to get under it and have a look. Is that noise the sound of a dry knife edge? Or is it something more serious? The shocker is pretty new (2k miles).
The noise is only really noticeable at lower speeds.
June 22nd, 2010, 11:35 pm
Post Re: Strange honky-parpy noise (left-rear) when going over bu
I'd guess your suspension can needs oiling ....
A picture speaks a 1000 words ....so here's the cure.
Remove the rubber gaiter ....
....insert the end of the oilcan spout and give it about 6 or 7 good pumps.
It helps if you can rotate the suspension can in between "pumps".
Dont use engine oil,gear oil,WD40 or LHM .....you need veggie oil, or castor oil .....[you could of course use "virgin olive oil" if you wanna do it the expensive way .... ;) ]
hth
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
June 23rd, 2010, 12:22 am
Hi Terry,
no 'normal brake fluid' either, when curing the grognement? :P
hth
T.
June 23rd, 2010, 12:28 am
ken wrote:
Hi Terry,
:lol: I never thought of that :oops: ;) .....I allus use "Crisp & Dry" me 8-) ....right concerned about my cars health I am .... :geek:
T. ;)
2CV6 Special [Red]
June 23rd, 2010, 12:37 am
Then open the hood, stand up inside the car, and bounce and shake it vigorously to get the oil splashing and sploshing around the innards. :lol:
June 23rd, 2010, 1:05 am
Or simply turn the can by hand?
June 23rd, 2010, 7:17 am
we got the same noise with the slough so looks like i'll be doing the same
June 23rd, 2010, 9:50 am
same problem,
turned the can around so hole in it faced upwards,
as if like magic no squeak, im going to put some oil in anyway,
what sort of oil pump is that?
and ive talked about this before, and had replies, but in your opinion is used cooking oil ok? its alot more viscous and alot less runny
June 23rd, 2010, 10:07 am
Or simply drive the car over a bumpy road
Castor oil is the oil to use for this problem. I use a syringe with a small tube on in that goes into the can. Cheap and easy ;')
June 23rd, 2010, 10:32 am
"what sort of oil pump is that?"
Oil 'pump'? Oh the one with 'Silverline Oil Can' on it's label..... :geek:
June 23rd, 2010, 10:36 am
