View unanswered posts | View active topics It is currently April 29th, 2026, 1:15 am
Reply to topic  [ 6 posts ]
 On this bit... rust proof?
Post On this bit... rust proof?
Hi all
On this bit:
Shall I Waxoil/Dinitrol it OR rustproof/paint it?
Charlie is gone. Now 2CVless.
June 18th, 2010, 8:10 pm
Post Re: On this bit... rust proof?
paint it, mine has some schultz (?) on it under the paint. .
June 18th, 2010, 8:13 pm
i would paint it as you would with any other panel. and then make sure you inject some sort of rust protection into the sill and underneath it.
June 18th, 2010, 8:15 pm
ok thanks will do that
June 18th, 2010, 8:59 pm
Paint it yellow, as it was when it left the factory (it would also have had a "chrome" strip on it).
June 18th, 2010, 9:26 pm
If you want it _perfect_ finish, get it primed & sprayed.
If you want it good (and staying good with minimal work), get it schutzed, then paint the top-coat on top.
Either way, cavity wax inside and underbody wax underneath.
June 18th, 2010, 10:10 pm
Users browsing this forum: No registered users and 105 guests
