View unanswered posts | View active topics It is currently June 19th, 2026, 8:23 am
 head off
Post head off
Any tips for separating the pot from the head?
one side came apart easy,one side stuck
I aren't doing it and the mecanic doesn't want to use brute force,
any help International bright young things?
Ta
Wal
March 22nd, 2009, 10:58 am
Online
Post Re: head off
Hi Wal,
If you have a vice, hold the bottom of the pot in a vice.
Use some cloth so you dont mark the pot.
(If your putting in new pots it doesnt matter how you treat it)
Careful with the heads.
Tap the bottom of the head with a mallet, careful as it is all fins.
Gentle taps all the way round it, should come off.
Hope this helps
March 22nd, 2009, 11:20 am
Post Re: head off
Cheers Pete
Passed it on
He just finished a Night rally in a subaru (whatever that is)sounded very fit when it left here last night,
thanks again
Wal
March 22nd, 2009, 1:51 pm
Post Re: head off
Wal,
another method, which avoids any chance of damaging the fins (or the barrel) is to use a length of timber, sitting _inside_ the barrel, as a drift.
Hold the assembly upside down by gripping the barrel with one hand and clout the drift with a hammer, altering the point at which the drift contacts the head to prevent the top spigot from tilting as the head starts separating from the barrel.
Make sure that there's something soft for the cylinder head to land on when it lets go...
Ken.
March 22nd, 2009, 3:05 pm
Online
Post Re: head off
must admit Ken, a better solution
March 22nd, 2009, 3:48 pm
Post Re: head off
Thanks again beards
Wal
What about brake lights on a 72 dyane ? bulbs check,switch check,fuses check, pissed off check
Ideas ?
March 22nd, 2009, 4:08 pm
Online
Post Re: head off
Is it a Dyane 4 or 6!
are other rear lights OK Check earth/corrision in the lamp holder
March 22nd, 2009, 6:13 pm
Post Re: head off
dyane 6
all other rear lights work fine
bulb holder is fine
March 23rd, 2009, 8:54 pm
Online
Post Re: head off
With lights on, in the boot, swap, side/brake light, brake light should come on
March 23rd, 2009, 9:06 pm
Post Re: head off
Cheers Pete
Done the power swap thing and the bulbs light up,so Im guessing no feed to the stop light system?
Is an extended waving arm still a recognised signal for braking across europe ?
Wal
March 29th, 2009, 7:48 pm
Users browsing this forum: No registered users and 226 guests
